Dialux Evo stopped working
anuj1980
Post by anuj1980 » Fri Jun 20, 2014 5:12 am
Hi ,
I have a problem while running the Dialux Evo. Each time I try to run it , it get stopped working. After that I have uninstalled the version and run
the latest version(i.e. 3.3) of it. Unfortunately the problem remains as it is.
Please find attached herewith the error message.
Kindly help me out & thanks in advance for the solution.
Anuj
Re: Dialux Evo stopped working
Post by kvkozierowski » Mon Jun 23, 2014 11:04 am
Hi Anuj,
this might happen if you use a computer with more than one graphics adapter (eg. a laptop with Intel and nvidia graphics).
In this case, please make sure to select the nvidia/AMD graphics adapter to be used with evo. You can change the graphics adapter via context menu off the evo desktop icon or via NVIDIA control panel.
anuj1980
Post by anuj1980 » Mon Jun 23, 2014 11:23 am
Hi Mr. Kolja,
Yes there are two graphic card.
Can you please tell me the process of selecting the Nvidia graphic adaptor for Evo with the help of
Screenshots.as i do not know.
Thanks for your reply.
Anuj
Post by kvkozierowski » Mon Jun 23, 2014 11:34 am
Hi Anuj,
Please find attached a screenshot of the required steps in the nvidia control panel, I have only the German version installed (sorry), but I think the GUI should be the same in another language. Add the program file (dialux_x64.exe or dialux_x86.exe) from the installation path of evo and select "NVIDIA High Performance Processor" or something similar.
Regards
anuj1980
Post by anuj1980 » Sat Jun 28, 2014 10:07 am
Hi Kolja ,
I have tried the way you advice . But I am not able to select the step 3 ( "NVIDIA High Performance Processor" or something similar).
Is there any other option to select this option . kindly let me know the steps to do it. I have attached the screenshots.
But when I installed Evo 3.1 version ,quite surprisingly it runs . So then I decide to try to run Evo 3.3 . It again stops running & same error reflect ( already posted in this thread) . Therefore I would like to ask why Evo 3.1 runs and whereas Evo 3.3 does not??
Thanks in advance.
Anuj
menu off the evo desktop icon.jpg (221.59 KiB) Viewed 41586 times
Setting of Manage 3 D Setting.jpg (196.06 KiB) Viewed 41586 times
Setting of Set PhysX Configuration.jpg (132.17 KiB) Viewed 41586 times
Post by kvkozierowski » Mon Jun 30, 2014 5:39 am
Hi Anuj,
evo 3.1 has a bit lower graphics adapter requirements and it supports Direct3D, evo 3.3 needs OpenGL support.
I do not know why you cannot select the NVIDIA GPU. Perhaps an update of the Intel and Nvidia drivers may help, but I really don't know, sorry.
Regards
sTEk
Post by sTEk » Mon Jun 30, 2014 9:53 am
You cannot change the prefered gpu here (see image)?
Anyway...maybe this helps:
http://ucdavistechtalk.wordpress.com/20 ... h-optimus/
M.Holthaus
Post by M.Holthaus » Thu Jul 24, 2014 8:33 am
Hi Anuj,
Maybe one of this points can help you:
https://forums.lenovo.com/t5/IdeaPad-Y- ... a-p/599561
Maurice
anuj1980
Post by anuj1980 » Thu Jul 24, 2014 2:40 pm
Hi Maurice / Kolja,
Finally i am able to run dialux Evo 3.3. Thanks for your link . By the help of this i am able to select the NVIDIA processor .
And also want to share one more thing about this ... i have updated the Intel Graphic card as well which i think help in doing this task.
:D :D
Anuj
