Select multiple luminaries for street lighting
NicklasH
Post by NicklasH » Thu Nov 24, 2016 2:40 pm
Hello
How do I select multiple luminaries to calculate optimal variants with?
In dialux 4 this is really easy using shift click or CONTROL+A to select all.
If I want to compare 50 different luminaries do I really have to click in every single box?
Gif animation example Dialux 4:
Dialux Evo appears a bit clunky to work with since it doesnt use windows built in object API's.
Gif animation example in Dialux Evo:
Am I doing something wrong? It cant be this complicated?
Re: Select multiple luminaries for street lighting
Post by Csuleiman » Fri Nov 25, 2016 7:46 am
Dear NicklasH,
You're right with your assumption. In evo you have to select each luminaire seperately in order to compare different luminaires. The way you can do it in DIALux 4 is not implemented yet in DIALux evo. So we will add your idea to our improvement list to implement such a simplification of the workflow in the upcoming evo versions.
NicklasH
Post by NicklasH » Fri Nov 25, 2016 7:50 am
Thank you for your response!
Then I will keep using Dialux 4 until a better way of selecting multiple luminaries is implemented in Dialux evo.
