Problem with starting DIALux 7.1 after installation
Wioletta
Post by Wioletta » Sun Aug 27, 2017 12:06 pm
Dear Team,
I have a problem with using DIALux 7.1 at PC with Windows 7.
Error statement:
Unbehandelte Ausnahme: Object reference not set to an instance of an object.
System.NullReferenceException
at Dial.Dialux.ProjectData.Management.AdviceManager.StartProgress()
at Dial.Dialux.ProjectData.Management.TransactionHelper..ctor(String name, Action`1 succeededCallback, Boolean broadcastChangeMessages)
at Dial.Dialux.ProjectData.Management.TransactionHelper.Transact(String name, Action`1 action)
at Dial.Dialux.InteractionProjectHandling.Base.ProjectHandling.NewProject()
at Dial.Dialux.InteractionProjectHandling.Base.ProjectHandling.NewProject(IProjectInitializer projectInitializer, IWorkspace workspace, WorkspaceActivationOption option)
at System.Windows.Input.CommandBinding.OnExecuted(Object sender, ExecutedRoutedEventArgs e)
at System.Windows.Input.CommandManager.ExecuteCommandBinding(Object sender, ExecutedRoutedEventArgs e, CommandBinding commandBinding)
at System.Windows.Input.CommandManager.FindCommandBinding(CommandBindingCollection commandBindings, Object sender, RoutedEventArgs e, ICommand command, Boolean execute)
at System.Windows.Input.CommandManager.FindCommandBinding(Object sender, RoutedEventArgs e, ICommand command, Boolean execute)
at System.Windows.Input.CommandManager.OnExecuted(Object sender, ExecutedRoutedEventArgs e)
at System.Windows.RoutedEventArgs.InvokeHandler(Delegate handler, Object target)
at System.Windows.RoutedEventHandlerInfo.InvokeHandler(Object target, RoutedEventArgs routedEventArgs)
at System.Windows.Input.RoutedCommand.ExecuteImpl(Object parameter, IInputElement target, Boolean userInitiated)
at MS.Internal.Commands.CommandHelpers.CriticalExecuteCommandSource(ICommandSource commandSource, Boolean userInitiated)
at System.Windows.Controls.MenuItem.InvokeClickAfterRender(Object arg)
Could you please help me ?
Thank you very much.
Wioletta
Re: Problem with starting DIALux 7.1 after installation
Post by Csuleiman » Mon Aug 28, 2017 6:24 am
Dear Wioletta,
Please have a look at the following thread:
https://dxboard.dialux.com/viewtopic.ph ... en#p101515
Wioletta
Post by Wioletta » Mon Aug 28, 2017 4:19 pm
Thank you, I have seen that topic jet.
But I have Windows 7 (not Win10). Despite of that I have done it - remove DIALux and installed again. Problem still exist.
Additionally ... yesterday I have done all update for Windows 7 and for graphic card.
Wioletta
Post by T.Magenheimer » Tue Aug 29, 2017 11:38 am
Dear Wioletta,
Can you please send us the whole error message text for an analysis of the problem?
You only have to copy the text out of the error message and paste it here.
Wioletta
Post by Wioletta » Tue Aug 29, 2017 4:13 pm
Of course. There it is. Thank you for your help.
Unbehandelte Ausnahme: Exception has been thrown by the target of an invocation.
at System.RuntimeMethodHandle.InvokeMethod(Object target, Object[] arguments, Signature sig, Boolean constructor)
at System.Reflection.RuntimeMethodInfo.UnsafeInvokeInternal(Object obj, Object[] parameters, Object[] arguments)
at System.Delegate.DynamicInvokeImpl(Object[] args)
at Dial.Dialux.Classlib.Tools.ModuleLoader.InvokeRegisteredInitMethods()
at Dial.Dialux.Classlib.Tools.ModuleLoader.InitializeModules(IEnumerable`1 modules, Action preDelayedInitAction)
at Dial.Dialux.Gui.DIALuxModuleLoader.InitializeModules()
at Dial.Dialux.Gui.MainWindow.OnLoaded(Object sender, RoutedEventArgs e)
at System.Windows.BroadcastEventHelper.BroadcastEvent(DependencyObject root, RoutedEvent routedEvent)
at System.Windows.BroadcastEventHelper.BroadcastLoadedEvent(Object root)
at MS.Internal.LoadedOrUnloadedOperation.DoWork()
at System.Windows.Media.MediaContext.FireLoadedPendingCallbacks()
at System.Windows.Media.MediaContext.FireInvokeOnRenderCallbacks()
at System.Windows.Media.MediaContext.RenderMessageHandlerCore(Object resizedCompositionTarget)
at System.Windows.Media.MediaContext.RenderMessageHandler(Object resizedCompositionTarget)
Inner Exception:
System.Runtime.InteropServices.SEHException
External component has thrown an exception.
at CCalcApp.CreateDefaultOptions(unique_ptr<Dial::Utilities::COptions\,std::default_delete<Dial::Utilities::COptions> >* )
at Dial.Dialux.Geometry.GeometryManager.GetDefaultCalculationOptions()
at Dial.Dialux.InteractionResultsHandling.SceneCalculation.CalculationSettings.DelayedInit(ModuleLoaderEventArgs args)
Post by T.Magenheimer » Wed Aug 30, 2017 9:06 am
Dear Wioletta,
Thank you very much for sending us the information needed. We will forward it to our development team for analysing the problem furthermore.
Till then we would recommend you to uninstall your evo7.1 version and install evo7.0 once again by using the link below.
https://b2b.dial.de/index.php/s/45uen8nZFenIMIo
Wioletta
Post by Wioletta » Fri Sep 01, 2017 7:49 am
Thank you very much for your support.
Dialux evo 8.0 works properly with Windows 7.
Post by T.Magenheimer » Fri Sep 01, 2017 7:54 am
Dear Wioletta,
Our DIALux evo version 7.1 also works with Windows 7.
Unfortunately it gives some problems with a few of our users with the evo 7.1 installation, which we will have fixed soon.
Post by T.Magenheimer » Wed Sep 13, 2017 7:16 am
Dear Wioletta,
Today we have released the first patch of our evo version 7.1.
With this version your problems are solved now.
You can download the setup of the patch using the following link: https://b2b.dial.de/index.php/s/5zdGX44Gyv8Zx7v
