Calculations Objects outside room
rassrollers
Post by rassrollers » Wed Sep 06, 2017 8:03 am
Hi
It has annoyed for a while.
When you draw a calculations object in form of a L, the centerpoint moves outside the room.
In the attachment i have tried to draw the area (Blue) in room 2/19/26 Fællesområder, but because the centerpoint (Green) is in Rum 15, the result apear in the wrong room.
Please make it so that the centerpoint doesn't move outside.
Regards Rasmus
Calculating surface-min-min.jpg (206.32 KiB) Viewed 464 times
Re: Calculations Objects outside room
Post by Csuleiman » Wed Sep 06, 2017 11:04 am
Dear rassrollers,
Yes, you're right. We will discuss this issue with our product owner to find an adequate improvement regarding this behavior.
TomVanRoey
Post by TomVanRoey » Thu Sep 07, 2017 6:20 am
Dear rassrollers,
That problem is easily solved.
Use the button "helplines and labeling"
Then you can select the text and move it.
There you can also change the font size, alignment, weight an colour of the text.
rassrollers
Post by rassrollers » Tue Sep 12, 2017 7:40 am
Dear TomVanRoey
It's not the text box, that is the issue.
It's when I draw a Polygonal calculation object, that the centerpoint or the xyz reference point is outside the room.
Post by T.Magenheimer » Tue Sep 12, 2017 11:20 am
Dear rassrollers,
This is a function that is currently not optimally solved. We will solve this problem as soon as possible
