Dwg import - incomplete drawing
Alexander Sidorov
Post by Alexander Sidorov » Wed Feb 07, 2018 12:02 pm
Hello!
This is an old question though maybe someone knows the answer.
When I'm trying to import cad drawing in dialux evo not everything from original drawing appears on the screen.
Polylines are a huge problem - they are simply not visible (and always were, since dialux 4.09).
Today I tried to import a drawing of an industrial cite masterplan and some information didn't appear though layers weren't either locked or frozen.
What may be wrong here and is there a way to fix such behaviour?
Alexander Sidorov
Re: Dwg import - incomplete drawing
Post by Alexander Sidorov » Thu Feb 08, 2018 9:09 am
If anyone is interested I've found a workaround:
in Autocad save the drawing as PDF then import resulting file back into Autocad (works since acad 2017).
beta-brandstedt
Post by beta-brandstedt » Thu Feb 08, 2018 10:46 am
Hi Alexander,
My experience with DIALux 4.xx and Evo are that neither of them support dwg with layers.
Use the Bind command on layers in Autocad or remove them altogether.
Johan Brandstedt
Atelje Lyktan
OS: Win 10E 64bit V1703
CPU: Intel Xeon Quad Core @ 3.50 GHz
GFX Card: Nvidia Quadro M4000 8GB DX11
Driver: 385.08
Ram: 16GB RAM
Alexander Sidorov
Post by Alexander Sidorov » Mon Feb 12, 2018 6:30 am
Hi Alexander,
Thanks for the advice, haven't tried this way yet.
I should add that for polylines explode command also helps. After being converted into lines they become visible in Dialux window.
