Drawing not Visible and then Dialux Crashes
EunRiv
Post by EunRiv » Mon Feb 12, 2018 3:37 pm
I've had the following issue several times, usually with larger drawing files but sometimes with smaller ones as well.
I was working on a project last week with no problem whatsoever. Saved and exited.
Today when I opened the project the drawing was not visible even though 'show DWG drawings' is selected.
When I click on Construction then Drawings, Dialux the window attached pops up and Dialux crashes and shuts down. What is this and why does this happen??? I need the drawing to reference the plan Drawing. Please help!
Re: Drawing not Visible and then Dialux Crashes
Post by Csuleiman » Tue Feb 13, 2018 7:49 am
Dear EunRiv,
Unfortunately you detected a bug in the current evo version. Our developer has already found a solution which will be implemented in the next evo version 8.0. We will release this version in the middle of March.
Till then we wonder if you could save the DWG drawing in an older AutoCAD file format, e.g. ACAD 2010 and then try to import it once again.
