error on installation
marco.aspg
Post by marco.aspg » Mon Sep 03, 2018 8:05 pm
I have a problem in the install Please can you help me
appears this error
Dependency Installation Script Cpuinfo , line 96 attemp to index local 'file' (a nil value)
stack traceback :
1: [Dependency Installation Script : CpuInfo ] Line : 96 in main Chunk
Re: error on installation
Post by Csuleiman » Tue Sep 04, 2018 6:07 am
Dear marco.aspg,
It seems to be as if the setup file was not downloaded completely and therefore corrupt. We wonder if you could try to download and install the evo version by using the following download link which leads you directly to the DIALux setup.
DIALux evo 8.0 Patch 3: https://b2b.dial.de/index.php/s/79MviIzDReBTcmJ
Please try to uninstall your older evo version completely from your computer system and install our newest evo 8.0 patch 3 version.
We would like to recommend you to deactivate all you security software (virus scanner) once on your computer system and after this please check if you can run the installation of DIALux evo8.0 without any problems.
ghevontk
Post by ghevontk » Sat Sep 08, 2018 5:49 pm
I deactivated antivirus, i installed the Dialux batch 3 , i received same message
Unbehandelte Ausnahme: Could not find a part of the path 'C:\Users\<UserName>\AppData\Local\DIAL GmbH\DIALux\UserRTables'.
System.IO.DirectoryNotFoundException
at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
at System.IO.FileSystemEnumerableIterator`1.CommonInit()
at System.IO.FileSystemEnumerableIterator`1..ctor(String path, String originalUserPath, String searchPattern, SearchOption searchOption, SearchResultHandler`1 resultHandler, Boolean checkHost)
at System.IO.DirectoryInfo.InternalGetFiles(String searchPattern, SearchOption searchOption)
at Dial.Dialux.StreetLighting.CalculationManager.RTableCollection.UpdateFromDirectory(IContext context, String path, Boolean userDefined)
at Dial.Dialux.StreetLighting.CalculationManager.RTableCollection.Update()
at Dial.Dialux.InteractionViewModels.Utilities.RTableSource.Update()
at Dial.Dialux.InteractionViewModels.ModuleInit.OnProjectCreated(Object sender, EventArgs e)
at System.EventHandler.Invoke(Object sender, EventArgs e)
at Dial.Dialux.Classlib.Extensions.EventExtensions.InvokeImpl(EventHandler handler, Object sender, Int32 maxExpectedListeners)
at Dial.Dialux.ProjectData.Management.ChangeManager.ReportProjectStatus(ProjectStatus projectStatus)
at Dial.Dialux.InteractionProjectHandling.Base.ProjectHandling.NewProject()
at Dial.Dialux.InteractionProjectHandling.Base.ProjectHandling.NewProject(IProjectInitializer projectInitializer, IWorkspace workspace, WorkspaceActivationOption option)
at System.Windows.Input.CommandBinding.OnExecuted(Object sender, ExecutedRoutedEventArgs e)
at System.Windows.Input.CommandManager.ExecuteCommandBinding(Object sender, ExecutedRoutedEventArgs e, CommandBinding commandBinding)
at System.Windows.Input.CommandManager.FindCommandBinding(CommandBindingCollection commandBindings, Object sender, RoutedEventArgs e, ICommand command, Boolean execute)
at System.Windows.Input.CommandManager.FindCommandBinding(Object sender, RoutedEventArgs e, ICommand command, Boolean execute)
at System.Windows.Input.CommandManager.OnExecuted(Object sender, ExecutedRoutedEventArgs e)
at System.Windows.RoutedEventArgs.InvokeHandler(Delegate handler, Object target)
at System.Windows.RoutedEventHandlerInfo.InvokeHandler(Object target, RoutedEventArgs routedEventArgs)
at System.Windows.Input.RoutedCommand.ExecuteImpl(Object parameter, IInputElement target, Boolean userInitiated)
at MS.Internal.Commands.CommandHelpers.CriticalExecuteCommandSource(ICommandSource commandSource, Boolean userInitiated)
at System.Windows.Controls.Primitives.ButtonBase.OnClick()
at System.Windows.Controls.Button.OnClick()
at System.Windows.Controls.Primitives.ButtonBase.OnMouseLeftButtonUp(MouseButtonEventArgs e)
at System.Windows.UIElement.ReRaiseEventAs(DependencyObject sender, RoutedEventArgs args, RoutedEvent newEvent)
at System.Windows.UIElement.OnMouseUpThunk(Object sender, MouseButtonEventArgs e)
at System.Windows.UIElement.RaiseTrustedEvent(RoutedEventArgs args)
at System.Windows.Input.InputManager.ProcessStagingArea()
at System.Windows.Input.InputManager.ProcessInput(InputEventArgs input)
at System.Windows.Input.InputProviderSite.ReportInput(InputReport inputReport)
at System.Windows.Interop.HwndMouseInputProvider.ReportInput(IntPtr hwnd, InputMode mode, Int32 timestamp, RawMouseActions actions, Int32 x, Int32 y, Int32 wheel)
at System.Windows.Interop.HwndMouseInputProvider.FilterMessage(IntPtr hwnd, WindowMessage msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
at System.Windows.Interop.HwndSource.InputFilterMessage(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
at MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
at MS.Win32.HwndSubclass.DispatcherCallbackOperation(Object o)
Post by Csuleiman » Mon Sep 10, 2018 7:04 am
Dear ghevontk,
Can you please check if the following path still exists on your computer system which is mentioned in your error message: 'C:\Users\<UserName>\AppData\Local\DIAL GmbH\DIALux\UserRTables'.
In case this folder is deleted, please delete the whole path and install our DIALux evo software once again.
Your DIALux team
