crash dialux evo 8
cakly
crash dialux evo 8
Post by cakly » Wed Sep 19, 2018 3:42 am
Hi everybody,
since this morning Dialux will crash with file open
i'm pretty sure not use Dell Backup and Recovery
Re: crash dialux evo 8
Post by Csuleiman » Wed Sep 19, 2018 5:45 am
Dear cakly,
As you got a Kernelbase.dll error message it seems to be the same problem as it is described in the following thread:
https://dxboard.dialux.com/viewtopic.ph ... se#p100396
Please check the suggestion to solution.
cakly
Post by cakly » Wed Sep 19, 2018 6:58 am
Reinstall after uninstalling
it's problem still happen.
Do you have any other helpful suggestions?
Post by Csuleiman » Wed Sep 19, 2018 7:01 am
Dear cakly,
Have you uninstalled Dell's Backup and Recovery utilities completely from your computer system? Or have you only reinstalled evo?
cakly
Post by cakly » Wed Sep 19, 2018 7:43 am
i'm not use Dell system, So I don't have this software.
yes, just only reinstalled evo
Post by Csuleiman » Wed Sep 19, 2018 9:38 am
Dear cakly,
You could try to clean up your system completely by doing the following:
1) Uninstalling the current DIALux evo version
2) Then delete the DIALux evo folder completely manually:
C:\Program Files\DIAL GmbH
3) Install our evo version 8 (patch 3) again on your system with the following download link:
DIALux evo 8 Patch 3: https://b2b.dial.de/index.php/s/79MviIzDReBTcmJ
If the problem continues to occur on your computer system, we are unable to help you because it is a special problem on your system. A new setup of the operating system will most likely solve the problem.
cakly
Post by cakly » Thu Sep 20, 2018 3:30 am
Thank you for your suggestion.
