LDT Editor
pavelkupcik
LDT Editor
Post by pavelkupcik » Mon Jan 14, 2019 10:46 am
Dear Dial,
I have a problem. I have edited the CRI value from 3000K to 5000K in LDT Editor. Then I saved the file and imported it into the Dialux (the latest version to date) and it still shows 3000K. It also renders images in yellow color (3000K) instead of neutral color (5000K). I have tried to edit the file in Windows´s Notepad but there wasn´t anything to edit because Notepad and LDT Editor both shows correct value of 5000K. Find some screenshots below as well as the affected file.
notepad+ldt editor.jpg (128.13 KiB) Viewed 782 times
Your answer will be highly appreciated.
Thank you
Pavel
wph-100w-002_fotometricka data.zip
(471 Bytes) Downloaded 46 times
Re: LDT Editor
Post by kvkozierowski » Mon Jan 14, 2019 11:33 am
Hello Pavel,
I think in your example the values for CRI and "color temperature of lamps" are switched.
The CRI has a maximum of 100 and a color temperature of 84K would be black.
pavelkupcik
Re: LDT Editor
Post by pavelkupcik » Wed Jan 16, 2019 12:34 pm
Hello Kolja,
you are right. I didn´t notice it. I was just focused on the values but not on the names of the fields.
Thank you very much
Pavel Kupcik
