Evo 8.1 crashes after calculation
koazc
Post by koazc » Mon Jan 14, 2019 9:21 pm
After running the calculations on a model I can just about orbit for a little while before the program crashes, freezing the computer in the process. I tried it on 2 different PCs. The model is available here(for 7 days).
This started happening at some point(don't quite know which :? ). Any ideas why this happens? Can anyone replicate the behavior?
Thank you in advance,
Re: Evo 8.1 crashes after calculation
Post by kvkozierowski » Tue Jan 15, 2019 8:19 am
Hello koazc,
I have tried it on my system and can replicate the issue. Here is the error message:
ERROR ...: Unbehandelte Ausnahme: Insufficient memory to continue the execution of the program.
System.OutOfMemoryException
at System.Windows.Media.Composition.DUCE.Channel.SyncFlush()
at System.Windows.Media.MediaContext.NotifyChannelMessage()
After calculation the charting generation consumes most of the available RAM (>12GB on my machine). We have already an open bug ticket concerning this issue planned for the next patch.
As a workaround I would suggest to disable the automatic charting generation for the project:
koazc
Post by koazc » Tue Jan 15, 2019 9:10 pm
Hello kvkozierowski,
Thank you very much for your support and quick reply!
Only the first checbox was checked in my case. I unchecked it and tried again. But no luck :( The problem is still there, crashing with the BSOD's VIDEO_MEMORY_MANAGEMENT_INTERNAL stop code.
I've run out of options at this point, I'll probably have to wait for the patch.
Thank you,
Post by Csuleiman » Wed Jan 16, 2019 9:00 am
Hello koazc,
Yes, I'm sorry, but you'll have to wait for the next patch.
koazc
Post by koazc » Wed Jan 16, 2019 7:06 pm
Thank you! I appreciate your work and support!
