Error during loading of the file. Evo 8.1 patch 3
AKStyle
Post by AKStyle » Thu May 16, 2019 7:51 am
Hello everyone!
I received a message when i tried to open my last project:
Error during loading of the file D:\Projects\2019\xxx\xxx\2019 05 07\Project 0.evo
Text of error:
Unbehandelte Ausnahme: Не удалось найти часть пути "C:\Users\<UserName>\AppData\Local\DIAL GmbH\DIALux\DIALuxProjectTemp\DXqac2rlf5\Project\Furniture\200x100_Konferenz_117_0\200x100_Konferenz.m3d".
System.IO.DirectoryNotFoundException
в System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
в System.IO.FileStream.Init(String path, FileMode mode, FileAccess access, Int32 rights, Boolean useRights, FileShare share, Int32 bufferSize, FileOptions options, SECURITY_ATTRIBUTES secAttrs, String msgPath, Boolean bFromProxy, Boolean useLongPath, Boolean checkHost)
в System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share, Int32 bufferSize, FileOptions options, String msgPath, Boolean bFromProxy, Boolean useLongPath, Boolean checkHost)
в System.IO.File.InternalReadAllBytes(String path, Boolean checkHost)
в Dial.Dialux.ProjectData.RepresentationData.Parts.BinaryVolumeRepresentationDataPart.DeSerialize(IArchiveRead archive)
в Dial.Dialux.Persistence.Step.StepArchiveReader.CreateMembers(StepObject obj)
в Dial.Dialux.Persistence.Step.StepArchiveReader.CreateObjectFromReference[T](String sReference, T& obj)
в Dial.Dialux.Persistence.Step.StepArchiveReader.Read(String name, Type type, IPersistent& obj)
в Dial.Dialux.Persistence.Interfaces.ArchiveReadWriteExtensions.Read[T](IArchiveRead archive, String name, T& obj)
в Dial.Dialux.Persistence.Interfaces.ArchiveDelegates.ReadPersistent[T](IArchiveRead archive, T& value)
в Dial.Dialux.Persistence.Interfaces.ArchiveDelegates.<>c__DisplayClass34_0`1.<ReadNamedCollection>b__0(Int32 count)
в Dial.Dialux.Persistence.Step.StepArchiveReader.Read(String name, Type type, Func`2 readColl)
в Dial.Dialux.Persistence.Interfaces.ArchiveDelegates.ReadNamedCollection[T](IArchiveRead archive, String name, ICollection`1 coll, Type collType, ReadDelegate`1 readValue)
в Dial.Dialux.ProjectData.RepresentationData.RepresentationDataWithParts.DeSerialize(IArchiveRead archive)
в Dial.Dialux.ProjectData.RepresentationData.GeometricRepresentationData.DeSerialize(IArchiveRead archive)
в Dial.Dialux.ProjectData.Representations.PrototypeGeometricRepresentation.DeSerialize(IArchiveRead archive)
в Dial.Dialux.ProjectData.PrototypeObjects.ProductPrototype.DeSerialize(IArchiveRead archive)
в Dial.Dialux.ProjectData.Management.ObjectManager.<>c__DisplayClass166_0.<ReadObjectCollection>b__4(IArchiveRead arc3, IPersistent& value2)
в Dial.Dialux.Persistence.Interfaces.ArchiveDelegates.ReadCollection[T](IArchiveRead archive, ICollection`1 coll, ReadDelegate`1 readValue)
в Dial.Dialux.Persistence.Interfaces.ArchiveDelegates.<>c__DisplayClass28_0`2.<ReadKeyValuePair>b__0(Int32 count)
в Dial.Dialux.Persistence.Interfaces.ArchiveDelegates.ReadKeyValuePair[TKey,TValue](IArchiveRead archive, KeyValuePair`2& pair, ReadDelegate`1 readKey, ReadDelegate`1 readValue)
в Dial.Dialux.ProjectData.Management.ObjectManager.<ReadObjectCollection>b__166_0(IArchiveRead arc1, KeyValuePair`2& value)
в Dial.Dialux.ProjectData.Management.ObjectManager.ReadObjectCollection(IArchiveRead archive)
в Dial.Dialux.ProjectData.Management.ObjectManager.DeSerialize(IArchiveRead archive)
в Dial.Dialux.Persistence.Step.StepArchiveReader.ReadFromExistingObject(String name, IPersistent obj)
в Dial.Dialux.ProjectData.Management.ProjectPersistenceHelper.LoadProjectData(IArchiveLoadHandler handler)
в Dial.Dialux.ProjectData.Management.ProjectPersistenceHelper.LoadProject(IArchiveLoadHandler handler)
в Dial.Dialux.ProjectData.Management.ProjectManager.Load(IArchiveLoadHandler handler)
в Dial.Dialux.InteractionFileHandling.LoadSave.LoadSaveManager.LoadProjectDataAndGeometry(String projectFilePath, LoadSaveResult& result)
в Dial.Dialux.InteractionFileHandling.LoadSave.LoadSaveManager.LoadProject(FileInfo fileInfo)
в Dial.Dialux.InteractionProjectHandling.Base.ProjectHandling.LoadProject(String filename)
в Dial.Dialux.Gui.MainWindowFileHandling.OpenFile(String filename)
в Dial.Dialux.Gui.MainWindowFileHandling.OnCommandLoadProject(Object sender, ExecutedRoutedEventArgs args)
в System.Windows.Input.CommandBinding.OnExecuted(Object sender, ExecutedRoutedEventArgs e)
в System.Windows.Input.CommandManager.ExecuteCommandBinding(Object sender, ExecutedRoutedEventArgs e, CommandBinding commandBinding)
в System.Windows.Input.CommandManager.FindCommandBinding(CommandBindingCollection commandBindings, Object sender, RoutedEventArgs e, ICommand command, Boolean execute)
в System.Windows.Input.CommandManager.FindCommandBinding(Object sender, RoutedEventArgs e, ICommand command, Boolean execute)
в System.Windows.Input.CommandManager.OnExecuted(Object sender, ExecutedRoutedEventArgs e)
в System.Windows.RoutedEventArgs.InvokeHandler(Delegate handler, Object target)
в System.Windows.RoutedEventHandlerInfo.InvokeHandler(Object target, RoutedEventArgs routedEventArgs)
в System.Windows.EventRoute.InvokeHandlersImpl(Object source, RoutedEventArgs args, Boolean reRaised)
в System.Windows.UIElement.RaiseEventImpl(DependencyObject sender, RoutedEventArgs args)
в System.Windows.Input.RoutedCommand.ExecuteImpl(Object parameter, IInputElement target, Boolean userInitiated)
в System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs)
в System.Windows.Threading.ExceptionWrapper.TryCatchWhen(Object source, Delegate callback, Object args, Int32 numArgs, Delegate catchHandler)
You can find this file on the link -
Could you fix that problem?
Thanks.
Re: Error during loading of the file. Evo 8.1 patch 3
Post by Csuleiman » Thu May 16, 2019 9:28 am
Hello AKStyle,
In your project file, some furniture objects could not be found, so we had to replace them with cubes. Afterwards, we were able to open your project file in evo. We will send you the repaired project file via WeTransfer within the next minutes.
