Texture Problem
SurfingChewie
Texture Problem
Post by SurfingChewie » Mon Nov 25, 2019 4:42 pm
Hi DIALux friends,
I am rather new in working with the DIALux Evo 8.2 software. I have attanded a training not long time ago and have to submit a homework in order to be certified.
Now I got a texture problem, which does not seem to be easy to solve...
The wall colours of the castle are supposed to be beige, but they are still partly default white, eventhough I have painted them. Depending on the view, they change colours and it seems, as if the colours are laying over each other.
Unfortunately I could not upload pictures to the board (the website always parsed an error), otherwise it would be easier for you guys to understand.
Does anyone have a clue where this texture problem is coming from and how to get rid of it?
I would be very grateful, if you can help me.
Thanky you very much in advance!
SurfingChewie
Re: Texture Problem
Post by Csuleiman » Tue Nov 26, 2019 7:31 am
Hi SurfingChewie,
Please be so kind as to provide us with the problematic evo project file for analysis and some screenshots showing the problem in details. It would be of help if you could send us the link to this topic so that we could better assign this issue.
SurfingChewie
Re: Texture Problem
Post by SurfingChewie » Tue Nov 26, 2019 12:11 pm
Dear DIALux-Support Team,
I have sent you an e-mail with the problematic file and a screenshot.
Thank you very much!
SurfingChewie
Re: Texture Problem
Post by Csuleiman » Fri Nov 29, 2019 7:39 am
Hello SurfingChewie,
Unfortunately, you constructed your building in the wrong way. It looks like you're only using cubes and other objects to build your building. The texture problems are also due to the wrong construction method.
The correct way is to draw the outer contours of your buildings and the inner contours of the rooms in the storey view. Only then will you receive correct calculation results and an ordered output.
Please watch the following tutorial on our YouTube channel to learn how to construct buildings:
https://www.youtube.com/watch?v=ROCB3FyOVTs
Users browsing this forum: No registered users and 4 guests
