DWG export (external scene) - diagonal lines of every object
kecy
Post by kecy » Thu Feb 27, 2020 11:46 pm
for some time I deal with strange error. It occures only when exporting external scene. Also this is not happening every time, i would say that maybe 50 % of cases. The problem is that all objects in the scene are "separated" diagonally while exported. That creates a mess in DWG export, where is just too many lines. The lines interconnects corners of objets.
Detail of stairs
What can I do to get rid of theese lines?
Thank you.
Miroslav Krejčí
Re: DWG export (external scene) - diagonal lines of every object
Post by Csuleiman » Fri Feb 28, 2020 8:21 am
Hello Miroslav,
You exported your DWG file when you were in the 3D view of evo, so you created a 3D DWG file. This is the reason why you have so many "crossing lines" in your DWG file. The solution for you is to export a DWG file in 2D view only, so you get a 2D DWG file without crossing lines.
kecy
Post by kecy » Sun Mar 01, 2020 11:30 pm
thank you very much for clarification. It seems now so obvious. :)))
Users browsing this forum: No registered users and 11 guests
