Street Lighting_Documentation
Posted: Sun Mar 29, 2020 3:38 pm
by pchai
Dear Team,
While working with street lighting in dialux evo, i realized that despite changing the connected load and luminous flux manually, these values are not depicted in documentation but just the initial values (not dimmed). What should i do so as to have the changed values in the documentation?
Best Regards,
pchai
Re: Street Lighting_Documentation
Posted: Mon Mar 30, 2020 6:58 am
Hello pchai,
The information given in the luminaire product data sheet always refers to the unmodified luminaire with the original manufacturer's data. If you now modify the luminaire and use it in road planning, you will only receive the modified values in the "Planning results" output page, which refers directly to the road scene. There you will also see the entry "user defined". Please have a look at the screenshots below.
Screenshot 1.JPG (233.77 KiB) Viewed 499 times
Screenshot 2.JPG (174.58 KiB) Viewed 499 times
Screenshot 3.JPG (203.34 KiB) Viewed 499 times
Posted: Mon Mar 30, 2020 7:25 am
by pchai
Many thanks for the prompt reply.
Best Regards,
Pchai
