DX9, Materials, texture
Posted: Tue May 05, 2020 9:44 am
by beta-pt
When i want select color from db-
Unbehandelte Ausnahme: Cíl vyvolání způsobil výjimku.
System.Reflection.TargetInvocationException
v System.RuntimeMethodHandle.InvokeMethod(Object target, Object[] arguments, Signature sig, Boolean constructor)
v System.Reflection.RuntimeMethodInfo.UnsafeInvokeInternal(Object obj, Object[] parameters, Object[] arguments)
v System.Delegate.DynamicInvokeImpl(Object[] args)
v System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs)
v System.Windows.Threading.ExceptionWrapper.TryCatchWhen(Object source, Delegate callback, Object args, Int32 numArgs, Delegate catchHandler)
Inner Exception:
System.Data.SQLite.SQLiteException
database disk image is malformed
v System.Data.SQLite.SQLite3.Reset(SQLiteStatement stmt)
v System.Data.SQLite.SQLite3.Step(SQLiteStatement stmt)
v System.Data.SQLite.SQLiteDataReader.Read()
v Dial.Dialux.InteractionCatalogs.StandardCatalogs.Base.CatalogBase.UpdateItems()
v Dial.Dialux.InteractionCatalogs.StandardCatalogs.Base.CatalogBase.set_SelectedCategory(CatalogCategory value)
v Dial.Dialux.StandardCatalogs.StandardCatalog.Show()
v Dial.Dialux.StandardCatalogs.Material.ColorMaterialPlugin.Show(Window parentWindow)
v System.Windows.Input.CommandBinding.OnExecuted(Object sender, ExecutedRoutedEventArgs e)
v System.Windows.Input.CommandManager.ExecuteCommandBinding(Object sender, ExecutedRoutedEventArgs e, CommandBinding commandBinding)
v System.Windows.Input.CommandManager.FindCommandBinding(Object sender, RoutedEventArgs e, ICommand command, Boolean execute)
v System.Windows.Input.CommandManager.OnExecuted(Object sender, ExecutedRoutedEventArgs e)
v System.Windows.RoutedEventArgs.InvokeHandler(Delegate handler, Object target)
v System.Windows.RoutedEventHandlerInfo.InvokeHandler(Object target, RoutedEventArgs routedEventArgs)
v System.Windows.EventRoute.InvokeHandlersImpl(Object source, RoutedEventArgs args, Boolean reRaised)
v System.Windows.UIElement.RaiseEventImpl(DependencyObject sender, RoutedEventArgs args)
v System.Windows.Input.RoutedCommand.ExecuteImpl(Object parameter, IInputElement target, Boolean userInitiated)
Re: DX9, Materials, texture
Posted: Wed May 06, 2020 12:35 pm
Hello beta-pt,
We would recommend you to uninstall your evo version and reinstall it once again. In this case, all DIALux components will be newly registered.
You could download the setup from our website or use the following download link.
Evo 9.0 patch 3: https://b2b.dial.de/index.php/s/W1aeMiUZSvhlfAX
