Unbehandelte Ausnahme: Modul OpenClipboard selhal (Výjimka na základě hodnoty HRESULT: 0x800401D0 (CLIPBRD_E_CANT_OPEN))
System.Runtime.InteropServices.COMException
v System.Runtime.InteropServices.Marshal.ThrowExceptionForHRInternal(Int32 errorCode, IntPtr errorInfo)
v System.Windows.Clipboard.Flush()
v System.Windows.Clipboard.CriticalSetDataObject(Object data, Boolean copy)
v System.Windows.Clipboard.SetDataInternal(String format, Object data)
v System.Windows.Input.CommandBinding.OnExecuted(Object sender, ExecutedRoutedEventArgs e)
v System.Windows.Input.CommandManager.ExecuteCommandBinding(Object sender, ExecutedRoutedEventArgs e, CommandBinding commandBinding)
v System.Windows.Input.CommandManager.FindCommandBinding(CommandBindingCollection commandBindings, Object sender, RoutedEventArgs e, ICommand command, Boolean execute)
v System.Windows.Input.CommandManager.FindCommandBinding(Object sender, RoutedEventArgs e, ICommand command, Boolean execute)
v System.Windows.Input.CommandManager.OnExecuted(Object sender, ExecutedRoutedEventArgs e)
v System.Windows.RoutedEventArgs.InvokeHandler(Delegate handler, Object target)
v System.Windows.RoutedEventHandlerInfo.InvokeHandler(Object target, RoutedEventArgs routedEventArgs)
v System.Windows.EventRoute.InvokeHandlersImpl(Object source, RoutedEventArgs args, Boolean reRaised)
v System.Windows.UIElement.RaiseEventImpl(DependencyObject sender, RoutedEventArgs args)
v System.Windows.Input.RoutedCommand.ExecuteImpl(Object parameter, IInputElement target, Boolean userInitiated)
v MS.Internal.Commands.CommandHelpers.CriticalExecuteCommandSource(ICommandSource commandSource, Boolean userInitiated)
v System.Windows.Controls.Primitives.ButtonBase.OnClick()
v System.Windows.Controls.Button.OnClick()
v System.Windows.Controls.Primitives.ButtonBase.OnMouseLeftButtonUp(MouseButtonEventArgs e)
v System.Windows.UIElement.ReRaiseEventAs(DependencyObject sender, RoutedEventArgs args, RoutedEvent newEvent)
v System.Windows.UIElement.OnMouseUpThunk(Object sender, MouseButtonEventArgs e)
v System.Windows.UIElement.RaiseTrustedEvent(RoutedEventArgs args)
v System.Windows.Input.InputManager.ProcessStagingArea()
v System.Windows.Input.InputManager.ProcessInput(InputEventArgs input)
v System.Windows.Input.InputProviderSite.ReportInput(InputReport inputReport)
v System.Windows.Interop.HwndMouseInputProvider.ReportInput(IntPtr hwnd, InputMode mode, Int32 timestamp, RawMouseActions actions, Int32 x, Int32 y, Int32 wheel)
v System.Windows.Interop.HwndMouseInputProvider.FilterMessage(IntPtr hwnd, WindowMessage msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
v System.Windows.Interop.HwndSource.InputFilterMessage(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
v MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
v MS.Win32.HwndSubclass.DispatcherCallbackOperation(Object o)
v System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs)
v System.Windows.Threading.ExceptionWrapper.TryCatchWhen(Object source, Delegate callback, Object args, Int32 numArgs, Delegate catchHandler)
DX9 info / copy to clipboard
Přemysl Tomšovic - Accredited trainer
Top osvětlení s.r.o.
http://www.top-osvetleni.cz
http://www.top-osvetleni.cz/sluzby/vypocty-osvetleni
http://www.top-osvetleni.cz/sluzby/mereni-osvetleni
- Contact:
Re: DX9 info / copy to clipboard
Hello beta-pt,
Thanks for the information,
I wonder if you could tell us what (where in evo) you tried to copy to the clipboard when his happened?
If you use some kind of "security" software (eg data loss prevention), please make sure that the clipboard access is not restricted.
