Evo 9 crashes the second time I open it.
deankipp
Post by deankipp » Tue May 26, 2020 10:32 pm
I downloaded evo 9. It worked the first time I used it. When I tried to open the program again it locked up on the black screen. :?
Re: Evo 9 crashes the second time I open it.
Post by Csuleiman » Wed May 27, 2020 9:15 am
Hi deankipp,
It seems to be as if something on your computer system goes wrong when connecting to the starting process of evo. Please try to deactivate all your security software (virus scanner and the firewall) once on your computer system and after this please check if the problem is solved.
In case the problem still exists, we would recommend you to uninstall your evo version and install the new patch version. In this case, all DIALux components will be newly registered. You could download the setup from our website or use the following download link.
Evo 9.0 patch 4: https://b2b.dial.de/index.php/s/Gkuu8vm12lZIIQW
After the installation, it would be better to restart the computer once.
Post by Csuleiman » Wed Jul 29, 2020 3:01 pm
Hi deankipp,
Please check the following suggested solution from a user:
https://dxboard.dialux.com/viewtopic.php?f=17&t=90505
Users browsing this forum: No registered users and 9 guests
