DIALUX Eco not launching
Ben85
Post by Ben85 » Tue Jun 23, 2020 7:22 am
Hi All,
I have installed DIALux Evo 9 successfully but it doesn't launch at all.
When I double-click the icon, the launch window appears then disappears and nothing more happens.
I need help with this please.
Thanks a lot
Re: DIALUX Eco not launching
Post by Csuleiman » Tue Jun 23, 2020 8:04 am
Hello Ben85,
It seems to be as if something on your computer system goes wrong when connecting to the starting process of evo. Please try to deactivate all your security software (virus scanner and the firewall) once on your computer system and after this please check if the problem is solved.
In case the problem still exists, we would recommend you to uninstall your evo version and install the new patch version. In this case, all DIALux components will be newly registered. You could download the setup from our website or use the following download link.
Evo 9.0 patch 4: https://b2b.dial.de/index.php/s/Gkuu8vm12lZIIQW
After the installation, it would be better to restart the computer once.
tayyababdullah
Post by tayyababdullah » Sun Jun 28, 2020 5:26 pm
I have same problem. i have installed evo9 when i lunch it open but not load the working screen. i have also attached pictures
dialux evo1.png (186.26 KiB) Viewed 222 times
dialux evo.png (143.67 KiB) Viewed 222 times
Post by Csuleiman » Mon Jun 29, 2020 8:01 pm
Hello tayyababdullah ,
Have you already tried the above mentioned solutions?
