Export Objects from Dialux
sjcardoso
Post by sjcardoso » Fri Jan 19, 2018 5:10 pm
Hi, i did an object in dialux file and i need to import it to another Dialux file. Can i use this object or i have do it again inside the file that i want to use to do some experiences?
I read some posts from years ago, and it says that export objects in dialux files is impossible but it's a point on your wishlist. It's already possible or unfortunately not ?
Thks!
kikeblackberry
Re: Export Objects from Dialux
Post by kikeblackberry » Mon Jan 22, 2018 9:34 pm
As you as noted, unfortunately, it is not possible to export objects (3ds or m3d files) yet. This wish is already standing on the developer team wishlist long time ago as you can see in this thread from 2014
https://dxboard.dialux.com/viewtopic.ph ... ect#p89579
Although, maybe this “workaround” will be useful: Mark created object (your custom object) as Favourite then close the application and then re-open it and load the new project file where you want to import this custom object. Just Navigate to object tab/select and click onto Favourites tab and there it will be.
