Documentation - Contour Room/walls
Andrefs
Post by Andrefs » Thu May 10, 2018 1:33 am
I'm needing a help wih Dialux documentation. In the output of the dialux program documentation is not appearing the walls of the rooms. Are there any settings that I should change?
In my project I imported a file into autocad and I drew all the walls, as it shows in the drawing.
Re: Documentation - Contour Room/walls
Post by T.Magenheimer » Fri May 11, 2018 7:23 am
Dear Andrefs,
We wonder if you could provide us with the problematic evo project file for further analysis. Our email address is 'Support@dial.de'.
Please send us also the link to this topic, so that we could better assign this issue.
Andrefs
Post by Andrefs » Mon May 14, 2018 6:03 pm
File Sent.
Thanks,
Post by T.Magenheimer » Thu May 17, 2018 8:53 am
Hi Andrè,
The reason for the problem was the cutout 6 in your project file. After we deleted this problematic cutout, the problem was solved.
We will analyze this problem in more detail and fix it in our next evo version. We will send you your repaired project file in a few minutes via WeTransfer.
