Editing Rooms
m.bauer
Editing Rooms
Post by m.bauer » Fri Mar 15, 2019 9:53 am
Simple problem.
I can't find any option in the the programm for me to:
- Change a room name
- Edit a room layout
- Delete a room
aso.
Where is the menue point to access these Options?
It is not mentioned in any of your turorials.
Thanks,
Martin
Re: Editing Rooms
Post by Csuleiman » Fri Mar 15, 2019 12:49 pm
Hi Martin,
You can change the room’s name directly in the tool “spaces”. Please select the room, which has to be renamed. Then you can write a new name in the field for the “name”. Please have a look at the screenshot below.
Screenshot 1.JPG (130.47 KiB) Viewed 2271 times
If you would like to change the room's layout, then you can do it easily in the storey view -> tool "storey and building construction". Please select the inner contour of the building as it is shown in the second screenshot and move or add points for the contour as required.
Screenshot 2.JPG (70.83 KiB) Viewed 2271 times
Once you have selected the inner contour of the room, you can delete it by pressing the DEL key.
m.bauer
Re: Editing Rooms
Post by m.bauer » Sat Mar 16, 2019 7:36 pm
Hi, thanks for the information ... now I knew what to search.
For anyone searching ... if you wanna select a room you need let go of the mouse in the wall next to room you wanna change.
not marking the area of the room or trying to select the room itself - but end the click in the wall.
