Vertical Illuminance - WELL
isamv
Post by isamv » Mon May 06, 2019 4:00 pm
I'm trying to calculate vertical illuminance at eye level, 45cm above the desk, and when looking at the different calculation surface's types, i get completeley different results when using the 'perpendicular calculation surface' compared to the 'vertical calculation surface' , ca 350lx difference in the result. For illuminance values at eye level which one should i use then? Perpendicular or vertical? Thanks in advance,
Re: Vertical Illuminance - WELL
Post by Csuleiman » Fri May 10, 2019 7:49 am
Hi isamv,
Perpendicular illuminance, for example, is an expression of the level of illuminance on a horizontal work plane, while vertical illuminance relates to a vertical plane. In the individual case the latter may also apply to such planes as a drawing board placed at an angle of 70°.
So in your case, you should use the perpendicular or horizontal illuminance.
