Add calculation parameters to a working plane
Sentinel
Post by Sentinel » Fri Feb 07, 2020 8:52 am
Hello
Is there a way to add a calculation parameter to an existing working plane?
I have drawn a building and rooms. Rooms are created with working planes automatically. But there is only one calculation parameter available (Perpendicular illuminance). I want to add UGR parameter, but can't seem to find a way to do that.
Do I really need to draw new calculation object to be able to add UGR parameter? This wouldn't be an issue, if I hadn't like a 100 rooms in my project. :(
Thanks.
Re: Add calculation parameters to a working plane
Post by Csuleiman » Fri Feb 07, 2020 9:11 am
Hello Sentinel,
The workplane is implemented according to the standard EN12464-1. You cannot change the parameters of a workplane as they always should be adaptively calculated.
Therefore, you have to insert a calculation grid to add the UGR parameter as required.
Sentinel
Post by Sentinel » Fri Feb 07, 2020 9:18 am
So in another words I have to draw a new calculation object manually for every room to be able to add UGR parameter?
Post by Csuleiman » Fri Feb 07, 2020 9:45 am
Yes, that's correct.
Sentinel
Post by Sentinel » Fri Feb 07, 2020 10:26 am
Thank you.
