Displaying of the table of illumination of the calculated surfaces
Alexey_R
Post by Alexey_R » Wed Apr 22, 2020 7:27 pm
My question concerns the table of the field of illumination of the calculated surfaces. Suppose each calculated surface is divided into 100x100 elementary areas. I need to get a table of illumination of each of these areas.
In Dialux 4.13, the illumination is displayed in the form of a table in the Table (E) option and is located below the Value Chart (E) option. At the same time, Table (E) displays the entire illumination table containing 100x100 values ​​and it can be copied to a text file. It is very comfortable!!!
In Dialux EVO 8.2, these options look different: they are replaced by the Value Grid (lx) and Value Chart (lx) options, respectively.
However, I didn't find the opportunity to display 100x100 illumination values ​​in a single table. In the Documentation, the table is divided into several parts, in which no more than 18 columns of illumination values ​​are displayed. Therefore, the data from Dialux EVO must first be collected from different parts, and then stitched into a single table. And so it is necessary to do for each design surface containing more than 18x18 areas on the design surface. The stitching process significantly slows down the work! So, for example, in Dialux EVO for the fields of illumination of the floor, ceiling and 4 walls, the process takes several tens of minutes, while in Dialux 4.13 finding and copying the 100x100 table will take no more than 20 seconds.
Now the question is: is it possible to display a 100x100 illumination table in Dialux EVO as a whole to quickly copy it and place it in a text file, rather than stitch this table from different pieces, spending a lot of time?
Re: Displaying of the table of illumination of the calculated surfaces
Post by T.Magenheimer » Tue Apr 28, 2020 3:11 pm
Dear Alexey_R,
Unfortunately the pictures cannot be displayed in your text. Please try to insert the pictures again, so that we understand the question better.
Alexey_R
Post by Alexey_R » Wed Apr 29, 2020 10:02 pm
These tables:
Dialux 4.13 => http://ibb.co.com/image/XR09K
Dialux EVO 8.2 => http://ibb.co.com/image/XRrXd
The question remains the same: how to derive the same large table as 4.13 in the EVO?
Post by Csuleiman » Tue May 12, 2020 11:49 am
Hello Alexey_R,
Unfortunately it is not possible to display such a table with 100x100 values as in DIALux 4.13.
