Dialux 4.13.02 - Windows 10 .NET framework issues.
pww235
Post by pww235 » Wed Oct 02, 2019 1:50 pm
Hello.
I cannot get Dialux 4 to install due to .NET Framework issues - the install crashes if I tell it to ignore the problem.
I have a brand new Windows 10 machine which has the most up to date framework yet the setup requests version 3.5 which has been superseded.
Is there any fix that does not require me to roll back my frameworks to enact the installation then reinstall the up to date version?
Regards,
Peter
Re: Dialux 4.13.02 - Windows 10 .NET framework issues.
Post by Csuleiman » Fri Oct 04, 2019 5:26 am
Hello Peter,
We assume that the DIALux 4 setup does not recognize the older .NET Framework versions on your computer. We recommend you to enable .NET Framework 3.5 in the control panel. Please proceed as described below:
https://docs.microsoft.com/de-de/dotnet ... ntrolPanel
