Problems with imported dwg files
Post by Krzysztof.korgol » Tue Jul 25, 2017 8:21 am
I am currenty using Dialux, I encountered a problem witch imported dwg files. After I import dwg file (dwg version 2010) my dialux is slowing down in 2D mode, in 3D mode everything is ok, problem is noticeable in indoor projects, in outdoor projects even witch big drawning dialux is running much better. In indoor projects, size of drawning seems to matter (bigger drawning bigger issues). I have Lenovo Legion Y520 with windows 10 64 bit, intel i5-7300HQ, NVIDIA geforce gtx 1050, 8gb RAM. Problem occurs on both graphic cards (integrated and nvidia). I reinstalled both dialux and drivers, my windows is updated. Can you help me with this problem? I ran dialux on my older computer and i encountered no such problem. Thank you in advance for reply.
Re: Problems with imported dwg files
Post by T.Magenheimer » Thu Aug 03, 2017 11:33 am
Dear Krzysztof.korgol,
Please try to change your graphic card driver under “File => Settings => General Options” (see attached screenshots) from Direct3D to OpenGL or from OpenGL to Direct 3D.
After that please start your DIALux software again and have a look if the problem still occurs.
Graphic driver 1.jpg (48.87 KiB) Viewed 436 times
Graphic driver 2.jpg (62.26 KiB) Viewed 436 times
