4.13 PDF Printer error 30
dbur
Post by dbur » Mon Oct 16, 2017 1:01 pm
Since I installed Dialux 4.13.0.0 on my Windows10 laptop, I'm unable to export PDF editions via the Dialux PDF Printer: I always have a message "Printer not activated - error code 30".
I've searched over the Web what this error was, modified the port of the driver, no way to get it to work as expected.
In the properties of the driver, I've found this (see image). Do we need an activation code to activate the printer ???
BTW, preview print works if I select another pdf driver (pdfcreator for instance)
Edit: problem persists after installation of verson 4.13.0.1
Help much appreciated, thanks in advance.
Re: 4.13 PDF Printer error 30
Post by Csuleiman » Tue Oct 17, 2017 12:40 pm
Dear dbur,
There is no activation code needed. Please save outputs with the DIALux pdf printer only over the function “Save output as PDF” (see attached screenshot 1).
When you select the “DIALux PDF Printer” over the printing menu you will get the activation error every time (see attached screenshots 2&3). Unfortunately it is not possible to use our DIALux printer in this menu.
PDF-Printer 1.jpg (34.13 KiB) Viewed 6943 times
PDF-Printer 2.jpg (73.81 KiB) Viewed 6943 times
PDF-Printer 3.jpg (30.78 KiB) Viewed 6943 times
In case the problem still occurs:
As a workaround you should try to print our DIALux outputs with an external PDF printer like the free Bullzip PDF printer:
http://www.chip.de/downloads/BullZip-PD ... 15777.html
dbur
Post by dbur » Sat Oct 21, 2017 7:21 am
Thanks for your answer,
Using the icon "Save output as PDF" gives me the same error (see images), so it is useless :(
The only way I can save the outputs is to select "Print" in the File menu and choose another driver than the Dialux PDF printer. I still don't know why...
I'm a teacher and my students don't have this problem on their desktop PC's (Win10)
pdf bug1.jpg (41.39 KiB) Viewed 6888 times
pdf bug2.jpg (67.69 KiB) Viewed 6888 times
Post by T.Magenheimer » Mon Oct 23, 2017 11:18 am
Dear dbur,
We would like to recommend you to uninstall your DIALux software from your system and install our DIALux 4.13.0.1 version to your computer system by using the following setup once again. In this case all DIALux components will be newly registered.
You can download the setup via the following link:
DIALux 4.13.0.1 setup: https://b2b.dial.de/index.php/s/cIIy2QlIAdD5Bjy
dbur
Post by dbur » Tue Oct 24, 2017 7:11 pm
Thank you very much, it works like a charm now ;-)
