I’m taking the liberty of contacting you to obtain information about the use of Dialux and Dialux Light (4.13).
*ldt files were associated by mistake to another app (Acrobat/Notepad etc…). When opening Dialux , we can’t right-click « Insert project » anymore. Despite restoring to default or associating to Dialux, it doesn’t work.
We’ve found a workaround by going through Dialux : « Select Luminaires » tab (bottom left)/ « Luminaires Files »/ Double click « Plugins »/slide to tab « Project/ Luminaires used », Enter and then Close. We do not save and start DiALUX Light.
This solution is tedious and inconvenient.
We use the Windows Server 2008 R2 operating system.
If you need futher information do not hesitate to contact us.
Looking forward to hearing from you.
D. Nguyen
Problem with ".ldt" file association
Re: Problem with ".ldt" file association
Dear DNguyen,
This seems to be a problem with your Windows operating system and a wrong file extension assignment.
Please read the following article to hopefully solve your problem:
http://www.thewindowsclub.com/change-fi ... ns-windows
