Setup Problem Dialux 4.13.02
eduardo_vidal
Post by eduardo_vidal » Tue Apr 17, 2018 11:03 am
Good afternoon.
I have been having a problem and could not solve myself even after researching the forum.
Installation for Dialux 4.13.02 crashes after it unzips, opens setup and i click 'continue" after choosing a installation folder.
After crashing I notice it had only installed the uninstall program.
Here is the error:
As I researched previous forum threads, I have already:
- Downloaded the setup file more than once
- Downloaded the setup file from other links i found on the forum, including ADMIN_SETP
- Erased all the remaining Dialux files before each attempt
- Run the unzipped setup file manually as ADM
- Stopped 3rd party and windows firewall and anti-virus
- Tried installing Dialux 7 and had the same problem
Here are the log lines with the PC configuration in the text (Windows 10.0.16299 in Portuguese)
[04/17/2018 08:39:31] Success Setup started: C:\Users\Eduardo\Desktop\DIALux 4.13.0.2 Setup\setup.exe
[04/17/2018 08:39:31] Notice Setup engine version: 9.5.1.0
[04/17/2018 08:39:31] Notice Product: DIALux, version 4.13.0.2
[04/17/2018 08:39:31] Success Language set: Primary = 22, Secondary = 1
[04/17/2018 08:39:31] Success Verify archive integrity
[04/17/2018 08:39:31] Skipped Date expiration check
[04/17/2018 08:39:31] Skipped Uses expiration check
[04/17/2018 08:39:31] Success System requirements check
[04/17/2018 08:39:31] Success Load plugin: C:\Users\Eduardo\AppData\Local\Temp\_ir_sf_temp_2\IRZip.lmd
[04/17/2018 08:39:31] Success Include script: _SUF70_Global_Functions.lua
[04/17/2018 08:39:31] Success Include script: CheckForDIALux.lua
[04/17/2018 08:39:31] Success Include script: RegistryFunctions.lua
[04/17/2018 08:39:31] Success Include script: LanguageCodes.lua
[04/17/2018 08:39:31] Success Include script: IdentifyCPU.lua
[04/17/2018 08:39:31] Success Include script: CheckDependencies.lua
[04/17/2018 08:39:31] Success Include script: PackagesFunctions.lua
[04/17/2018 08:39:31] Success Include script: SystemInfo.lua
[04/17/2018 08:39:31] Success Include script: UserInfo.lua
[04/17/2018 08:39:31] Success Include script: ConfigureDIALux.lua
[04/17/2018 08:39:31] Success Include script: Uninstall.lua
[04/17/2018 08:39:31] Success Include script: Setup.lua
[04/17/2018 08:39:31] Success Include script: GlobalFunctions.lua
[04/17/2018 08:39:31] Success Include script: FileInstall.lua
[04/17/2018 08:39:31] Success Include script: Maintenance.lua
[04/17/2018 08:39:31] Success Include script: Prerequisites.lua
[04/17/2018 08:39:31] Success Include script: SystemInfoWriter.lua
[04/17/2018 08:39:31] Success Include script: SelectInstallFolder.lua
[04/17/2018 08:39:31] Success Include script: CDPatch.lua
[04/17/2018 08:39:31] Success Include script: AdminSetup.lua
[04/17/2018 08:39:31] Success Include script: GlobalOptions.lua
[04/17/2018 08:39:31] Success Include script: Update.lua
[04/17/2018 08:39:31] Success Include script: Startup.lua
[04/17/2018 08:39:31] Success Include script: Shutdown.lua
[04/17/2018 08:39:31] Success Include script: Shortcuts.lua
[04/17/2018 08:39:31] Notice Start project event: Global Functions
[04/17/2018 08:39:31] Success Run project event: Global Functions
[04/17/2018 08:39:31] Success Detection Script: AntiHack
[04/17/2018 08:39:31] Success Extract dependency file: C:\Users\Eduardo\AppData\Local\Temp\_ir_sf_temp_2\antihack\AntiHack.exe
[04/17/2018 08:39:31] Success Create folder: C:\Users\Eduardo\AppData\Local\Temp\_ir_sf_temp_2\antihack\
[04/17/2018 08:39:31] Success Extract dependency file: C:\Users\Eduardo\AppData\Local\Temp\_ir_sf_temp_2\antihack\DialComUpdater.exe
[04/17/2018 08:39:31] Error Script: Dependency Installation Script: AntiHack, Line 123 (1022)
[04/17/2018 08:39:31] Notice Start project event: On Startup
[04/17/2018 08:39:31] Notice Language Code: 22 1
[04/17/2018 08:39:32] Debug Language Code: 1046
[04/17/2018 08:39:32] Debug change System Language Token to: PT-BR
[04/17/2018 08:39:32] Notice System language not supported from DIALux
[04/17/2018 08:39:32] Notice Selected language: EN-GB, 2057, English (UK)
[04/17/2018 08:39:32] Notice Analyse command line arguments
[04/17/2018 08:39:32] Debug Command line arg 1: C:\Users\Eduardo\AppData\Local\Temp\_ir_sf_temp_2\irsetup.exe
[04/17/2018 08:39:32] Debug Command line arg 2: __IRCT:0
[04/17/2018 08:39:32] Notice OS: Windows 10
[04/17/2018 08:39:32] Notice OS Version: 10.0.16299
[04/17/2018 08:39:32] Notice Check a previous setup for failure.
[04/17/2018 08:39:32] Notice Load table DIALux.tDetails
[04/17/2018 08:39:32] Notice Load table Setup.tPreviousSettings
[04/17/2018 08:39:32] Notice Run "Clean" Setup after crash
[04/17/2018 08:39:32] Info Intel(R) Core(TM) i7-4510U CPU @ 2.00GHz
[04/17/2018 08:39:32] Info Ram: 8075
[04/17/2018 08:39:32] Notice Identify CPU: Family 6 Model 69
[04/17/2018 08:39:32] Notice CPU type: 1
[04/17/2018 08:39:32] Notice DirectX Version: 4.09.00.0904
[04/17/2018 08:39:32] Notice DirectX 9(c) or greater already on system
[04/17/2018 08:39:32] Notice MDAC Version: 6.3.9600.16384
[04/17/2018 08:39:32] Notice JET Version: 4.0.9801.0
[04/17/2018 08:39:32] Notice IE Version: 9.11.16299.0
[04/17/2018 08:39:33] Success Run project event: On Startup
[04/17/2018 08:39:33] Success Display screen: Welcome to Setup
[04/17/2018 08:39:34] Success Display screen: License Agreement
[04/17/2018 08:39:36] Success Display screen: Select Install Folder
[04/17/2018 08:39:37] Notice Check install folder: C:\Program Files (x86)\DIALux
[04/17/2018 08:39:37] Notice InstallDir is ok!
[04/17/2018 08:39:37] Debug correct path: |C:\Program Files (x86)\DIALux| => |C:\Program Files (x86)\DIALux|
[04/17/2018 08:39:37] Success Display screen: Select Packages
[04/17/2018 08:39:39] Success Display screen: Ready to Install
[04/17/2018 08:39:40] Notice Start project event: On Pre Install
[04/17/2018 08:39:40] Success Run project event: On Pre Install
[04/17/2018 08:39:40] Success Set uninstall data folder: C:\Program Files (x86)\DIALux\Uninstall
[04/17/2018 08:39:40] Success Set uninstall config file name: C:\Program Files (x86)\DIALux\Uninstall\uninstall.xml
[04/17/2018 08:39:40] Success Uninstall config file not merging
[04/17/2018 08:39:40] Success Create folder: C:\Program Files (x86)\DIALux\
[04/17/2018 08:39:40] Success Create folder: C:\Program Files (x86)\DIALux\Uninstall\
[04/17/2018 08:39:40] Success Create uninstall data folder: C:\Program Files (x86)\DIALux\Uninstall
[04/17/2018 08:39:40] Success Create uninstall data file: C:\Program Files (x86)\DIALux\Uninstall\uninstall.dat
[04/17/2018 08:39:40] Success Create folder: C:\WINDOWS\DIALux\
Thank you in advance if you can help.
Eduardo
Re: Setup Problem Dialux 4.13.02
Post by Csuleiman » Wed Apr 18, 2018 8:59 am
Dear eduardo_vidal,
We are totally not sure why you get such serious problems. But it could be a problem that Windows has corrupted the DIALux permissions on your computer system with an update in the past. The only way to solve this problem is to manually delete all DIALux components that are still on your computer system after uninstalling DIALux 4.13.
In the following you will find a list what you must delete on your computer system that you hopefully can install our software product successfully on your computer system:
1. Uninstall everything completely: DIAlux 4, DIALux Communication Framework, DIAL Data Dispatcher (see attached screenshot)
2. Delete the program folders of DIALux 4 (C: \ Program Files (x86))
3. Delete also this folder (C: \ ProgramData \ DIAL GmbH, C: \ ProgramData \ DIALux)
4. And this folder (C: \ Users \ <username> \ AppData \ Local \ DIAL GmbH)
These are our default installation paths. If you have adjusted them, you will need to adjust the paths accordingly.
After this you should restart your computer once and then reinstall DIALux 4 once again. Please try to download and install the DIALux 4.13.0.2 setup once again by using the following link: https://b2b.dial.de/index.php/s/HePRxzOhXb6U5hG
If you do not feel confident enough, it's best to ask your administrator for help and, if necessary, make backup copies of the deleted folders on your desktop.
Some users informed us that this is a Windows problem with an update, it helped other users to reinstall the Windows operating system. Maybe you can try it out.
