Problem Launcing Osram Lamps Plgins
afulea
Post by afulea » Fri Nov 29, 2019 9:14 am
Hi everyone
I have problems launching the Osram Lamp Plugin on my PC. On another PC this is possible, however the lamp importation on to Dialux is not working.
Anyone has already have this issue?
lamp plugin not available.jpg (29.14 KiB) Viewed 1753 times
lamp plugin.jpg (69.42 KiB) Viewed 1753 times
importation not possible.jpg (118.89 KiB) Viewed 1753 times
Re: Problem Launcing Osram Lamps Plgins
Post by Csuleiman » Fri Nov 29, 2019 1:02 pm
Hello afulea,
Unfortunately, we have to inform you that Osram Lamp terminated our project partnership at the end of 2017. It is therefore no longer possible to use the lamp plugin in evo nor DIALux 4.
We can only recommend that you use a different lamp plugin.
afulea
Post by afulea » Tue Dec 03, 2019 8:32 am
Hello.
Thannk you for your answer. Can you tell what other lamp plugin is working with Dialux? I tried Tungsram but is the same. Philips is not for download anymore.
Thank you in advance.
Post by Csuleiman » Tue Dec 03, 2019 9:16 am
Hello afulea,
This button is not active for all luminaire files in all cases. It depends on the manufacturer himself whether he is willing to offer the possibility to change the lamp within the original luminaire file. In your case, this button is greyed out because the luminaire manufacturer does not allow the lamp to be replaced. Alternative lamp plugins are available from Megaman and as you mentioned Tungsram.
