How to change type of a created calculation object?
MP7
Post by MP7 » Wed May 22, 2019 8:10 am
coming from Relux so I need some time to adapt to Dialux :)
How do you change an already created calculation object to a work area and also select an appropriate working area values according to EN-12464-1/2 ?
Thank you.
Re: How to change type of a created calculation object?
Post by Csuleiman » Fri May 24, 2019 12:42 pm
Hello MP7,
A workplane is automatically created for each room and space. It is not possible to convert a calculation surface into a workplane. However, you can set further parameters for the calculation surface. In the calculation objects tool, you will also find all setting options for the workplane.
Please have a look at the two articles from our knowledge base:
https://evo.support-en.dial.de/support/ ... ion-object
https://evo.support-en.dial.de/support/ ... on-objects
