individual floors
bofarull2003
individual floors
Post by bofarull2003 » Sun May 31, 2020 4:35 pm
Hi, I´m starting with dialux and can´t use individual floor materials for each room, what (except room 1). Can you help me? thanks.
Re: individual floors
Post by Csuleiman » Wed Jun 03, 2020 7:45 am
Hello bofarull2003,
You can insert a thin cube, which has the appropriate room geometry, into the separated room. Then you will be able to use a another texture/ material just for this area. Or the better way would be to create this room by using new indoor contour. Then you will have a real room in a room. If you click on the SHIFT key whilst drag&drop the colour to the floor, you will only get for one room and one floor the material as required. Maybe you can check it out.
