I've searched also in other topics but I couldn't find an answer for the following questions, so I try to ask you. If I checked in a bad way, I apologize.
1. In the Façade elements panel we can change the layer configuration of the apertures: on the right we can find two arrows, so I guess that we can add new layers above or below the one already existing, do not we? Do you know how to use this function?
2. Is there a way to select all the luminaires of the same kind with a single click?
Thanks in advance.
My best regards.
Layer configuration + Selection
Re: Layer configuration + Selection
I have the same question regarding luminaire selection.
I can't seem to find a way to do this...it would make editing lamp colour and type a lot easier.
Hello White and hello 64_Richard,
Please have a look at the following article from our knowledge base, which provides you with some more detailed information about this topic:
https://evo.support-en.dial.de/support/ ... -skylights
Under the following link you will find our video tutorial about daylight control systems:
https://www.youtube.com/watch?v=kcmReHd ... OGRKdkAAYW
Regarding the second point, there is unfortunately no possibility to select all luminaires of the same type in the complete project with only one click. However, we will gladly add this topic to our evo improvement list.
