Opaque materials reflectance: LRV or L* ?
Clem&D
Post by Clem&D » Thu Jun 22, 2017 3:00 pm
Greetings,
I have a question regarding the definition of opaque materials in Dialux.
Based on manufacturer specifications, 2 parameters co-exist to define reflectance :
- Light Reflectance Value (LRV): total quantity of visible light reflected by a surface ;
- L* : visual contrast.
Dialux database seems to use L* as reference for reflectance definition, while LRV would seem more appropriate.
Which parameter would you recommend using for materials definition in Dialux?
Best,
Clément
Light brown material with 34% reflectance: L* seems to be used.
Paremeter definition from DESSO (carpet tiles):
Re: Opaque materials reflectance: LRV or L* ?
Post by Csuleiman » Fri Jun 23, 2017 7:22 am
Dear Clem&D,
DIALux uses L* for reflectance definition. The value for reflection (which is Rho in DIALux) indicates how much of the arriving light is being reflected. Please mind that values over 80% are barely present in practical life. Therefore DIALux is limited to a value of 90%. The reflection factor in DIALux is calculated using the RGB-values.
Clem&D
Post by Clem&D » Fri Jun 23, 2017 1:31 pm
Thanks for the quick answer.
Best,
Clément
