documentation
Posted: Wed Apr 04, 2018 8:01 am
by Uri
Dear sirs, please help.
When you click the documentation button, the program gives an error.
How can the situation be remedied?
Unbehandelte Ausnahme: Инициализатор типа "System.Windows.Media.Fonts" выдал исключение.
System.TypeInitializationException
в Dial.Dialux.OutputXml.Params.BasicFontParams.FontFamilyIsAvailable(String fontFamily)
в Dial.Dialux.OutputXml.Params.BasicFontParams.SelectFont(String font)
в Dial.Dialux.OutputXml.Params.BasicFontParams..ctor()
в Dial.Dialux.OutputXml.Params.ParamsFactory.get_BasicFontParams()
в Dial.Dialux.OutputManager.OutputConverter.InitParams(String paramsFile)
в Dial.Dialux.OutputManager.OutputConverter.CreateFormattedOutputXF(FileInfo xmlSourceFile)
в Dial.Dialux.OutputManager.OutputConverter.CreatePagePdfOutput(IPage page)
в Dial.Dialux.OutputManager.OutputPageCache.CreatePdfDocumentForPage(IPage page)
в Dial.Dialux.OutputManager.OutputManager.ShowPage(IPage page)
в Dial.Dialux.OutputManager.OutputManager.set_SelectedItem(IOutputTreeElement value)
в Dial.Dialux.OutputManager.OutputManager.OnActivated()
в Dial.Dialux.InteractionToolManagement.ToolManager.TryShowMode(IMode newMode, ToolClassification toolClassification)
в Dial.Dialux.Gui.Controls.Main.ModeSelectionControl.OnTabSelectionChanged(Object sender, SelectionChangedEventArgs args)
в System.Windows.RoutedEventArgs.InvokeHandler(Delegate handler, Object target)
в System.Windows.RoutedEventHandlerInfo.InvokeHandler(Object target, RoutedEventArgs routedEventArgs)
в System.Windows.EventRoute.InvokeHandlersImpl(Object source, RoutedEventArgs args, Boolean reRaised)
в System.Windows.UIElement.RaiseEventImpl(DependencyObject sender, RoutedEventArgs args)
в System.Windows.Controls.TabControl.OnSelectionChanged(SelectionChangedEventArgs e)
в System.Windows.Controls.Primitives.Selector.SelectionChanger.End()
в System.Windows.Controls.Primitives.Selector.SetSelectedHelper(Object item, FrameworkElement UI, Boolean selected)
в System.Windows.Controls.Primitives.Selector.NotifyIsSelectedChanged(FrameworkElement container, Boolean selected, RoutedEventArgs e)
в System.Windows.Controls.TabItem.OnSelected(RoutedEventArgs e)
в System.Windows.Controls.TabItem.OnIsSelectedChanged(DependencyObject d, DependencyPropertyChangedEventArgs e)
в System.Windows.DependencyObject.OnPropertyChanged(DependencyPropertyChangedEventArgs e)
в System.Windows.FrameworkElement.OnPropertyChanged(DependencyPropertyChangedEventArgs e)
в System.Windows.DependencyObject.NotifyPropertyChange(DependencyPropertyChangedEventArgs args)
в System.Windows.DependencyObject.UpdateEffectiveValue(EntryIndex entryIndex, DependencyProperty dp, PropertyMetadata metadata, EffectiveValueEntry oldEntry, EffectiveValueEntry& newEntry, Boolean coerceWithDeferredReference, Boolean coerceWithCurrentValue, OperationType operationType)
в System.Windows.DependencyObject.SetValueCommon(DependencyProperty dp, Object value, PropertyMetadata metadata, Boolean coerceWithDeferredReference, Boolean coerceWithCurrentValue, OperationType operationType, Boolean isInternal)
в System.Windows.DependencyObject.SetCurrentValueInternal(DependencyProperty dp, Object value)
в System.Windows.Controls.TabItem.OnPreviewGotKeyboardFocus(KeyboardFocusChangedEventArgs e)
в System.Windows.UIElement.RaiseTrustedEvent(RoutedEventArgs args)
в System.Windows.Input.InputManager.ProcessStagingArea()
в System.Windows.Input.InputManager.ProcessInput(InputEventArgs input)
в System.Windows.Input.KeyboardDevice.TryChangeFocus(DependencyObject newFocus, IKeyboardInputProvider keyboardInputProvider, Boolean askOld, Boolean askNew, Boolean forceToNullIfFailed)
в System.Windows.Input.KeyboardDevice.Focus(DependencyObject focus, Boolean askOld, Boolean askNew, Boolean forceToNullIfFailed)
в System.Windows.Input.KeyboardDevice.Focus(IInputElement element)
в System.Windows.UIElement.Focus()
в System.Windows.Controls.TabItem.SetFocus()
в System.Windows.Controls.TabItem.OnMouseLeftButtonDown(MouseButtonEventArgs e)
в System.Windows.UIElement.ReRaiseEventAs(DependencyObject sender, RoutedEventArgs args, RoutedEvent newEvent)
в System.Windows.UIElement.OnMouseDownThunk(Object sender, MouseButtonEventArgs e)
в System.Windows.Input.InputProviderSite.ReportInput(InputReport inputReport)
в System.Windows.Interop.HwndMouseInputProvider.ReportInput(IntPtr hwnd, InputMode mode, Int32 timestamp, RawMouseActions actions, Int32 x, Int32 y, Int32 wheel)
в System.Windows.Interop.HwndMouseInputProvider.FilterMessage(IntPtr hwnd, WindowMessage msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
в System.Windows.Interop.HwndSource.InputFilterMessage(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
в MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
в MS.Win32.HwndSubclass.DispatcherCallbackOperation(Object o)
в System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs)
в System.Windows.Threading.ExceptionWrapper.TryCatchWhen(Object source, Delegate callback, Object args, Int32 numArgs, Delegate catchHandler)
Inner Exception:
System.IO.FileFormatException
No FontFamily element found in FontFamilyCollection that matches current OS or greater: Windows7SP1
в MS.Internal.FontFace.CompositeFontParser.Fail(String message, Exception innerException)
в MS.Internal.FontFace.CompositeFontParser..ctor(Stream fileStream)
в MS.Internal.FontCache.FamilyCollection.SystemCompositeFonts.GetCompositeFontFamilyAtIndex(Int32 index)
в MS.Internal.FontCache.FamilyCollection.GetFontFamilies(Uri fontFamilyBaseUri, String fontFamilyLocationReference)
в System.Windows.Media.Fonts.CreateFamilyCollection(Uri fontLocation, Uri fontFamilyBaseUri, String fontFamilyLocationReference)
в System.Windows.Media.Fonts..cctor()
Inner Exception:
в MS.Internal.FontFace.CompositeFontParser.ParseFontFamilyCollectionElement()
Re: documentation
Posted: Wed Apr 04, 2018 8:13 am
Dear Uri,
Please have a look at the following thread: https://dxboard.dialux.com/viewtopic.ph ... ts#p102355
