IFC import for Dialux EVO?
Dathaí o'Bardáin
Post by Dathaí o'Bardáin » Wed Nov 25, 2015 5:09 pm
Hi, Does anyone know when we can expect to import ifc files into dialux evo? I saw a post that said 2016 but has a date been set?
Re: IFC import for Dialux EVO?
Post by T.Magenheimer » Thu Nov 26, 2015 10:46 am
Dear Dathaí o'Bardáin,
This feature will be definitely implemented in one of our next evo versions, but I can't give you an exact time at the moment.
RJHellemons
Post by RJHellemons » Tue Jan 12, 2016 11:50 am
Hello, wen this year? ore is there a revit model import?
Post by Csuleiman » Wed Jan 13, 2016 8:29 am
Dear RJHellemons,
We have planned to implement this feature at the end of this year, but we would not give you an exact date.
You can download the plugin for Revit from the website of Autodesk: http://www.autodesk.com/education/free- ... /revit-mep
If case of any further assistance regarding the Revit plugin, we would like to recommend you to get directly in contact with Autodesk. After installing this plugin you’re able to use the command “dialuxexport” or “dialuximport”.
Currently it is possible to import DWG, 3DS, SAT and STF files into DIALux evo.
Novezeil
Post by Novezeil » Thu Jan 14, 2016 11:23 am
Csuleiman wrote:Dear RJHellemons,
Hi Csuleiman, the url you given is for standard revit download. Is it STF Exporter you are referring for the plugin? Or there is another one?
Post by Csuleiman » Thu Jan 14, 2016 12:51 pm
Dear Novezeil,
Yes, you're right. We meant the STF interface for the plugin.
