Light Scenes & Calculation Surfaces
64_Richard
Post by 64_Richard » Fri Sep 01, 2017 11:20 am
I've set up a project with two light scenes.
1) General Lighting
2) General Lighting + Task Lighting in which I've added extra desk lamps etc.
Is it possible to calculate only Work Planes in the first scene and only Task Areas in the second?
Thank you,
Richard.
64_Richard
Re: Light Scenes & Calculation Surfaces
Post by 64_Richard » Fri Sep 01, 2017 11:22 am
Sorry, to add...
If the above is possible, could I add third scene - Emergency Lighting and add a separate calculation Surface for the Open Area?
Post by Csuleiman » Tue Sep 05, 2017 9:48 am
Dear 64_Richard,
In the current evo7.1 version you can switch to the "Fast" mode. Then only the visible part of the building will be calculated. You just have to disable the workplane or task area in the results overview and then calculate only the "calculation surfaces". Please find attached the screenshots.
The emergency lighting is not available yet in evo. Next year we will integrate the feature of emergency lighting in evo. Till then we would like to recommend every user to work with DIALux 4.13 regarding the emergency lighting planning.
