Dialux 7.1 Crashes in installation process.
ederfs
Post by ederfs » Thu Oct 26, 2017 3:56 pm
Dear Dial Support,
After following and installing all versions of Dialux Evo since the beggining (I had been a official trainner some years ago, and keed trainning)) Now I can't install the software version 7.1.
This problem occurs both on my Notebook and Desktop.
Notebook after close all apps (antivirus, sinchronizers, etc.). Fighting against the problem the installation pass.
Over the Desktop.. no way! Luckily I just switch my HDD to a SSD drive and I could initialize the 7.0 version from the old folder in old drive.
When you click next in the first screen (after system check and Microsoft Visual C++ Check and install), the process crashes and the close the install application (see image attached).
I've tried to close all applications.. but without success.
Can someone help me?
Thank you so much.
Eder Ferreira
Computer
Dell XPS8700
8Gb RAM
2GB Video Board (Nvidia GTX 650)
SSD 240gb
HDD 1Tb
Windows 10 Pro Version 1703 Updated.
Antivirus = Windows Defender
Re: Dialux 7.1 Crashes in installation process.
Post by kvkozierowski » Fri Oct 27, 2017 5:52 am
Dear Eder Ferreira,
This sounds like a damaged setup file. Please try to download the setup again and reinstall evo 7.1.
ederfs
Post by ederfs » Tue Oct 31, 2017 12:41 pm
Hello Kolja,
Thank for reply and sorry for late answer. I forgot to check the notify box.
I've download the installation file several times (exactly five times).
If you have another idea will be worderfull.
By this time I'll continue use the 7.0 and waiting a 7.2 version and try again!
Tks
Post by Csuleiman » Fri Nov 03, 2017 9:52 am
Dear ederfs,
We would like to recommend you to use the following download link of evo7.1:
https://b2b.dial.de/index.php/s/45uen8nZFenIMIo
Besides this please deactivate all you security software (virus scanner and the firewall) once on your computer system and after this please check if you can install evo without any problems.
If you have a bad feeling to disable the security software, you can deactivate your WLAN connection and remove the network cable from your computer.
ederfs
Post by ederfs » Wed Nov 08, 2017 12:35 pm
Hello Csuleiman, good morning.
The link is about 7.0. But no problem.
At first time I tried to deactivate all the network adaptors (WAN and LAN) and removed the cable. Didn't work.
Second I deactivated my second hard drive (put it on offline mode in the disk manager). Didn't work.
So I deactivated the Windows Defender (virus base only). Didn't work.
Finaly, I deactivated the firewall. It works! \o/
Only to better understand, I did all this complementary, keeping the first actions!
Thank you so much by the support!
Post by Csuleiman » Wed Nov 08, 2017 12:48 pm
Dear ederfs,
We are pleased hearing that you managed to solve the problem by yourself. We regret sending you the wrong download link. Here ist the correct one which leads you directly to the evo7.1 (patch 1) setup file:
https://b2b.dial.de/index.php/s/5zdGX44Gyv8Zx7v
ederfs
Post by ederfs » Wed Nov 08, 2017 4:22 pm
I forgot to tell that the file installed was the website one (7.1 downloaded directly from the dial.de
By the way! I didn't solve by myself. I only followed the instructions step by step and register here to help anyone with the same problem and help dial to understand what is going on, improving the installation process! ;)
Best regards!
Eder
Post by kvkozierowski » Thu Nov 09, 2017 6:56 am
Dear Eder,
Would you please tell us which firewall you are using? The Windows standard firewall or a 3rd party product?
So far we are not aware of problems with the setup and firewalls.
ederfs
Post by ederfs » Thu Nov 09, 2017 12:25 pm
The standard one!
Like I said, I did step by step, deactivating the firewall at end, plus all the first steps.
But... windows is a mistery! :)
Best Regards,
Eder
Pascoal Daprile
Post by Pascoal Daprile » Sat Nov 11, 2017 2:17 pm
I had exactly the same problem.
