REAL TIME CALCULATION IS DIFFERENT THAN REPORT
frandr1
Post by frandr1 » Thu Sep 05, 2019 7:52 pm
Thanks everyone for the opportunity to discuss this problem I am having
While doing a sports calculation, the real time calculation gives me information for the Em Emin Emax different to what is then printed on the report. All the values are lower in real time calculation than in the report.
Shouldn't they be the same? :shock:
Re: REAL TIME CALCULATION IS DIFFERENT THAN REPORT
Post by T.Magenheimer » Fri Sep 06, 2019 8:15 am
Dear frandr1,
When working with the real-time calculation feature you will get results, which are calculated in real-time. The output shows you the regular calculation, which is accurately.
You will always get the right calculation results after calculating the scene. The real-time calculation is just a rough overview of results (overhead calculator). It is helpful during the lighting planning. So to be sure that you will get the correct results, you need to calculate in the normal way the whole project.
frandr1
Post by frandr1 » Fri Sep 06, 2019 2:50 pm
thank you very much for the support
