Which format do Dialux evo support to Export/ Import?
Travis Designer
Post by Travis Designer » Sat Apr 25, 2020 9:23 am
Hi
I search a lot keyword in google. But can not find the official site show:
I has tested import DWG, IFC
Import 3DS file as furniture
I looking for exporting format.
Travis
Re: Which format do Dialux evo support to Export/ Import?
Post by Csuleiman » Tue Apr 28, 2020 12:23 pm
Hello Travis,
In evo you have the possibility to use the import function for DWG/DXF drawings, STF, IFC and 3DS files. Under the following link you will find an informational document about the data exchange from CAD programs to DIALux and back again.
https://b2b.dial.de/index.php/s/e7x1IQiTddfIHrg
Export is currently a topic in our development. There are different formats under discussion and the order is defined by the amount of users that need the feature and the necessity for the lighting design process. For example export to Word, Excel, PowerPoint, ETIM, GAEB, IFC and STF.
From the current point of view without having finally discussed this, we would assume that a release of an IFC export is realistic in 2021. Probably the IFC export will be developed earlier.
In DIALux, import/export is alternatively available via the DWG interface.
Travis Designer
Post by Travis Designer » Wed Apr 29, 2020 7:04 am
Thank for your details feedback @Csuleiman
