Problem with documentation
krailo
Post by krailo » Thu Jan 18, 2018 3:54 pm
Hello
When i go to documentation, DIALux show me text below
Sometimes it crashes the program, but usually i can use the rest functions of DIALux (except documentation).
Have someone solved this problem earlier?
I hope you can help me
Thanks a lot!
Unbehandelte Ausnahme: The type initializer for 'System.Windows.Media.Fonts' threw an exception.
System.TypeInitializationException
at Dial.Dialux.OutputXml.Params.BasicFontParams.FontFamilyIsAvailable(String fontFamily)
at Dial.Dialux.OutputXml.Params.BasicFontParams.SelectFont(String font)
at Dial.Dialux.OutputXml.Params.BasicFontParams..ctor()
at Dial.Dialux.OutputXml.Params.ParamsFactory.get_BasicFontParams()
at Dial.Dialux.OutputManager.OutputConverter.InitParams(String paramsFile)
at Dial.Dialux.OutputManager.OutputConverter.CreateFormattedOutputXF(FileInfo xmlSourceFile)
at Dial.Dialux.OutputManager.OutputConverter.CreatePagePdfOutput(IPage page)
at Dial.Dialux.OutputManager.OutputPageCache.CreatePdfDocumentForPage(IPage page)
at Dial.Dialux.OutputManager.OutputManager.ShowPage(IPage page)
at Dial.Dialux.OutputManager.OutputManager.set_SelectedItem(IOutputTreeElement value)
at Dial.Dialux.OutputManager.OutputManager.OnActivated()
at Dial.Dialux.InteractionToolManagement.ToolManager.TryShowMode(IMode newMode, ToolClassification toolClassification)
at Dial.Dialux.Gui.Controls.Main.ModeSelectionControl.OnTabSelectionChanged(Object sender, SelectionChangedEventArgs args)
at System.Windows.RoutedEventArgs.InvokeHandler(Delegate handler, Object target)
at System.Windows.RoutedEventHandlerInfo.InvokeHandler(Object target, RoutedEventArgs routedEventArgs)
at System.Windows.EventRoute.InvokeHandlersImpl(Object source, RoutedEventArgs args, Boolean reRaised)
at System.Windows.UIElement.RaiseEventImpl(DependencyObject sender, RoutedEventArgs args)
at System.Windows.Controls.TabControl.OnSelectionChanged(SelectionChangedEventArgs e)
at System.Windows.Controls.Primitives.Selector.SelectionChanger.End()
at System.Windows.Controls.Primitives.Selector.SetSelectedHelper(Object item, FrameworkElement UI, Boolean selected)
at System.Windows.Controls.Primitives.Selector.NotifyIsSelectedChanged(FrameworkElement container, Boolean selected, RoutedEventArgs e)
at System.Windows.Controls.TabItem.OnSelected(RoutedEventArgs e)
at System.Windows.Controls.TabItem.OnIsSelectedChanged(DependencyObject d, DependencyPropertyChangedEventArgs e)
at System.Windows.DependencyObject.OnPropertyChanged(DependencyPropertyChangedEventArgs e)
at System.Windows.FrameworkElement.OnPropertyChanged(DependencyPropertyChangedEventArgs e)
at System.Windows.DependencyObject.NotifyPropertyChange(DependencyPropertyChangedEventArgs args)
at System.Windows.DependencyObject.UpdateEffectiveValue(EntryIndex entryIndex, DependencyProperty dp, PropertyMetadata metadata, EffectiveValueEntry oldEntry, EffectiveValueEntry& newEntry, Boolean coerceWithDeferredReference, Boolean coerceWithCurrentValue, OperationType operationType)
at System.Windows.DependencyObject.SetValueCommon(DependencyProperty dp, Object value, PropertyMetadata metadata, Boolean coerceWithDeferredReference, Boolean coerceWithCurrentValue, OperationType operationType, Boolean isInternal)
at System.Windows.DependencyObject.SetCurrentValueInternal(DependencyProperty dp, Object value)
at System.Windows.Controls.TabItem.OnPreviewGotKeyboardFocus(KeyboardFocusChangedEventArgs e)
at System.Windows.UIElement.RaiseTrustedEvent(RoutedEventArgs args)
at System.Windows.Input.InputManager.ProcessStagingArea()
at System.Windows.Input.InputManager.ProcessInput(InputEventArgs input)
at System.Windows.Input.KeyboardDevice.TryChangeFocus(DependencyObject newFocus, IKeyboardInputProvider keyboardInputProvider, Boolean askOld, Boolean askNew, Boolean forceToNullIfFailed)
at System.Windows.Input.KeyboardDevice.Focus(DependencyObject focus, Boolean askOld, Boolean askNew, Boolean forceToNullIfFailed)
at System.Windows.Input.KeyboardDevice.Focus(IInputElement element)
at System.Windows.UIElement.Focus()
at System.Windows.Controls.TabItem.SetFocus()
at System.Windows.Controls.TabItem.OnMouseLeftButtonDown(MouseButtonEventArgs e)
at System.Windows.UIElement.ReRaiseEventAs(DependencyObject sender, RoutedEventArgs args, RoutedEvent newEvent)
at System.Windows.UIElement.OnMouseDownThunk(Object sender, MouseButtonEventArgs e)
at System.Windows.Input.InputProviderSite.ReportInput(InputReport inputReport)
at System.Windows.Interop.HwndMouseInputProvider.ReportInput(IntPtr hwnd, InputMode mode, Int32 timestamp, RawMouseActions actions, Int32 x, Int32 y, Int32 wheel)
at System.Windows.Interop.HwndMouseInputProvider.FilterMessage(IntPtr hwnd, WindowMessage msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
at System.Windows.Interop.HwndSource.InputFilterMessage(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
at MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
at MS.Win32.HwndSubclass.DispatcherCallbackOperation(Object o)
at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs)
at System.Windows.Threading.ExceptionWrapper.TryCatchWhen(Object source, Delegate callback, Object args, Int32 numArgs, Delegate catchHandler)
Inner Exception:
System.IO.FileFormatException
No FontFamily element found in FontFamilyCollection that matches current OS or greater: Windows7SP1
at MS.Internal.FontFace.CompositeFontParser.Fail(String message, Exception innerException)
at MS.Internal.FontFace.CompositeFontParser..ctor(Stream fileStream)
at MS.Internal.FontCache.FamilyCollection.SystemCompositeFonts.GetCompositeFontFamilyAtIndex(Int32 index)
at MS.Internal.FontCache.FamilyCollection.GetFontFamilies(Uri fontFamilyBaseUri, String fontFamilyLocationReference)
at System.Windows.Media.Fonts.CreateFamilyCollection(Uri fontLocation, Uri fontFamilyBaseUri, String fontFamilyLocationReference)
at System.Windows.Media.Fonts..cctor()
Inner Exception:
at MS.Internal.FontFace.CompositeFontParser.ParseFontFamilyCollectionElement()
Re: Problem with documentation
Post by kvkozierowski » Fri Jan 19, 2018 6:24 am
Hello krailo,
This is a Microsoft .NET issue: https://github.com/Microsoft/dotnet/issues/599
There is nothing we can do about it but there are some workarounds mentioned that should help you.
Best regrads
