Error openinig DIAlux evo
RicardoDIAL
Post by RicardoDIAL » Mon Jul 08, 2019 3:51 am
Regards,
They could help me, I have a problem when trying to open the DIALux. I just downloaded the program, I installed it and at the moment of opening it, the following message appears:
Unbehandelte Ausnahme: Se produjo una excepción en el destino de la invocación.
System.Reflection.TargetInvocationException
en System.RuntimeMethodHandle.InvokeMethod(Object target, Object[] arguments, Signature sig, Boolean constructor)
en System.Reflection.RuntimeMethodInfo.UnsafeInvokeInternal(Object obj, Object[] parameters, Object[] arguments)
en System.Delegate.DynamicInvokeImpl(Object[] args)
en Dial.Dialux.Classlib.Tools.ModuleLoader.InvokeRegisteredInitMethods()
en Dial.Dialux.Classlib.Tools.ModuleLoader.InitializeModules(IEnumerable`1 modules, Action preDelayedInitAction)
en Dial.Dialux.Gui.DIALuxModuleLoader.InitializeModules()
en Dial.Dialux.Gui.MainWindow.OnLoaded(Object sender, RoutedEventArgs e)
en System.Windows.EventRoute.InvokeHandlersImpl(Object source, RoutedEventArgs args, Boolean reRaised)
en System.Windows.UIElement.RaiseEventImpl(DependencyObject sender, RoutedEventArgs args)
en System.Windows.BroadcastEventHelper.BroadcastEvent(DependencyObject root, RoutedEvent routedEvent)
en System.Windows.BroadcastEventHelper.BroadcastLoadedEvent(Object root)
en MS.Internal.LoadedOrUnloadedOperation.DoWork()
en System.Windows.Media.MediaContext.FireLoadedPendingCallbacks()
en System.Windows.Media.MediaContext.FireInvokeOnRenderCallbacks()
en System.Windows.Media.MediaContext.RenderMessageHandlerCore(Object resizedCompositionTarget)
en System.Windows.Media.MediaContext.RenderMessageHandler(Object resizedCompositionTarget)
en System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs)
en System.Windows.Threading.ExceptionWrapper.TryCatchWhen(Object source, Delegate callback, Object args, Int32 numArgs, Delegate catchHandler)
Inner Exception:
en System.RuntimeTypeHandle.CreateInstance(RuntimeType type, Boolean publicOnly, Boolean noCheck, Boolean& canBeCached, RuntimeMethodHandleInternal& ctor, Boolean& bNeedSecurityCheck)
en System.RuntimeType.CreateInstanceSlow(Boolean publicOnly, Boolean skipCheckThis, Boolean fillCache, StackCrawlMark& stackMark)
en System.Activator.CreateInstance(Type type, Boolean nonPublic)
en System.Activator.CreateInstance(Type type)
en Dial.Dialux.Gui.Controls.Main.ModeControlMapper.GetContentForMode(Type modeType)
en Dial.Dialux.Gui.Controls.Main.ModeSelectionControl.DelayedInit(ModuleLoaderEventArgs args)
Inner Exception:
System.Windows.Markup.XamlParseException
La invocación del constructor del tipo 'Dial.Dialux.Gui.Controls.CAD.RenderView' que coincide con las restricciones de enlace especificadas produjo una excepción.
en System.Windows.Markup.XamlReader.RewrapException(Exception e, IXamlLineInfo lineInfo, Uri baseUri)
en System.Windows.Markup.WpfXamlLoader.Load(XamlReader xamlReader, IXamlObjectWriterFactory writerFactory, Boolean skipJournaledProperties, Object rootObject, XamlObjectWriterSettings settings, Uri baseUri)
en System.Windows.Markup.WpfXamlLoader.LoadBaml(XamlReader xamlReader, Boolean skipJournaledProperties, Object rootObject, XamlAccessLevel accessLevel, Uri baseUri)
en System.Windows.Markup.XamlReader.LoadBaml(Stream stream, ParserContext parserContext, Object parent, Boolean closeStream)
en Dial.Dialux.Gui.Controls.Modes.CAD.CadModeSubControl..ctor()
en Dial.Dialux.Gui.Controls.Modes.CAD.BaseCadModeControl.CreateCadModeSubControl()
en Dial.Dialux.Classlib.Tools.ModuleLoader.DelayedInit(DelayedInitMethod delayedInitMethod)
en Dial.Dialux.Gui.Controls.Modes.CAD.CadModeControl..ctor()
Inner Exception:
System.AccessViolationException
Intento de leer o escribir en la memoria protegida. A menudo, esto indica que hay otra memoria dañada.
en Dial.Dialux.Geometry.ScenegraphControl.Create(ScenegraphControl* , Void* , ISettingsProvider* , IPolygonHelper* , IUserAdviceHandler* , IRedrawTrigger* , CRenderListener* )
en Dial.Dialux.Geometry.GeometryManager.InitScenegraphDevice(IntPtr hWnd, ModuleLoaderEventArgs args)
en Dial.Dialux.Gui.Controls.CAD.RenderView.InitSceneGraph(ModuleLoaderEventArgs args)
en Dial.Dialux.Gui.Controls.CAD.RenderView.DelayedInit(ModuleLoaderEventArgs args)
en Dial.Dialux.Gui.Controls.CAD.RenderView..ctor()
I would appreciate your support
Re: Error openinig DIAlux evo
Post by Csuleiman » Mon Jul 08, 2019 6:31 am
Hello RicardoDIAL,
We would like to recommend you to update the graphics adapter driver on the manufacturer's website of your graphics card and not by the help of Windows.
Please have a look at the following threads:
http://dxboard.dialux.com/viewtopic.php?f=29&t=80338
http://dxboard.dialux.com/viewtopic.php?f=29&t=80337
http://dxboard.dialux.com/viewtopic.php?f=17&t=78016
Hopefully, this will solve your problem.
Users browsing this forum: No registered users and 6 guests
