experiencing problems with PDF export (Japanese).
physis
Post by physis » Sun Jan 31, 2021 1:34 am
I installed the 9.2 version and started using it immediately, but I am experiencing problems with PDF export (Japanese).
Specifically, when I set up the export page in the document, select "PDF" from "Save As", and export
When I set up the export page in the document and select "PDF" from "Save As" to export, characters other than numbers (English, Japanese) are displayed as □, causing the problem described above.
Until 9.1 version, this problem did not occur at all.
I had no choice. I use the "Print" command to export PDF files.
I don't know if it's a problem with my PC or with the text settings in the new version.
Thank you for your help.Image
PDF documentation
DATA 2.jpg (60.24 KiB) Viewed 702 times
App Documentation
Re: experiencing problems with PDF export (Japanese).
Post by Csuleiman » Mon Feb 01, 2021 9:23 am
Hello physis,
You have unfortunately detected a bug in the current evo 9.2 version with Asian fonts. Our developers have already fixed this problem for the upcoming evo patch version.
Until then we can only recommend as a workaround to create the PDF by printing with Print2Pdf.
