DIALUX EVO 9.2 problem with documentation
Hajzler
Post by Hajzler » Tue Feb 02, 2021 5:55 am
Dear all.
When I want to open the documentation tab, this message pops up. What with this?
Thank youu verymuch for your help.
Neošetřená výjimka: Cíl vyvolání způsobil výjimku.
System.Reflection.TargetInvocationException
v System.RuntimeMethodHandle.InvokeMethod(Object target, Object[] arguments, Signature sig, Boolean constructor)
v System.Reflection.RuntimeMethodInfo.UnsafeInvokeInternal(Object obj, Object[] parameters, Object[] arguments)
v System.Delegate.DynamicInvokeImpl(Object[] args)
v System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs)
v System.Windows.Threading.ExceptionWrapper.TryCatchWhen(Object source, Delegate callback, Object args, Int32 numArgs, Delegate catchHandler)
Inner Exception:
v System.RuntimeTypeHandle.CreateInstance(RuntimeType type, Boolean publicOnly, Boolean noCheck, Boolean& canBeCached, RuntimeMethodHandleInternal& ctor, Boolean& bNeedSecurityCheck)
v System.RuntimeType.CreateInstanceSlow(Boolean publicOnly, Boolean skipCheckThis, Boolean fillCache, StackCrawlMark& stackMark)
v System.Activator.CreateInstance(Type type, Boolean nonPublic)
v System.Activator.CreateInstance(Type type)
v Dial.Dialux.Gui.Controls.Main.ModeControlMapper.GetContentForMode(Type modeType, Type toolType)
v Dial.Dialux.Gui.Controls.Main.ModeSelectionControl.ShowContentForTabItem(ModeTabItem tabItem)
v System.EventHandler`1.Invoke(Object sender, TEventArgs e)
v Dial.Dialux.Classlib.Interfaces.Extensions.EventExtensions.InvokeImpl[T](EventHandler`1 handler, Object sender, T oldValue, T newValue)
v Dial.Dialux.InteractionToolManagement.ToolManager.InvokeActiveToolChanged(ITool oldTool, ITool newActiveTool)
v Dial.Dialux.InteractionToolManagement.ToolManager.TryShowTool(Type typeOfTool)
v Dial.Dialux.InteractionToolManagement.ToolManager.TryShowMode(IMode newMode, ToolClassification toolClassification)
v Dial.Dialux.Gui.Controls.Main.ModeSelectionControl.DispatchedSetMode(Mode mode)
Inner Exception:
System.IO.FileNotFoundException
Soubor nebyl nalezen.
v System.Drawing.Text.PrivateFontCollection.AddFontFile(String filename)
v Stimulsoft.Base.StiFontCollection.AddFontFile(String fileName, String alias)
v Dial.Dialux.Gui.Controls.Modes.Output.OutputModeControl..ctor()
Re: DIALUX EVO 9.2 problem with documentation
Post by T.Magenheimer » Tue Feb 02, 2021 7:43 am
Dear Hajzler,
After an intensive analysis, we have now definitely found out that there is a problem with the correct loading of fonts under Windows 7.
The only way to solve the problem at the moment is to install Windows 10 on the affected computer systems.
Otherwise, we ask you to currently work with our evo version 9.1 (Patch 1) until we have released the next patch, which will then also solve the problem under Windows 7.
Here is the download link for the evo 9.1 (Patch 1) setup: https://b2b.dial.de/index.php/s/kc4ajkN5VwYWWgo
We are sorry that you have these problems with the new evo version!
belysningseje
Post by belysningseje » Wed Feb 03, 2021 1:43 pm
Dear Admin
It seems only possible to make a clean install after upgrading to newer version. Will all the addons be lost as contacts, objects i.e extrusion bodys and so on?
Kind regards
Eje
Post by T.Magenheimer » Thu Feb 04, 2021 5:06 pm
Dear Hajzler,
We will release a first patch for our evo version 9.2 in the next days, in which this bug is fixed.
