Min value in measure grid different from results overview
gbr
Post by gbr » Wed Mar 03, 2021 4:12 pm
I've noticed that the Min values on the measure grid are different from the values tabulated in the Results Overview Panel. This happens for the Workplane calculation type. And this affects the Average and Uniformity results. See attached Workplane.jpg image file.
When using Rectangular Calculation Object the Min result value in the grid is the same as in the Results Overview Panel. See Calculation Surface 1.jpg image file.
Is there a way to get the correct value in the Worplane Calculation? Since this is the calculation surface that is created by default when creating a room.
Or should I just create a new Calculation Object for each room to get the correct results?
Details for both calculations
Type of calculation: Perpendicular Illuminance
Z position: 0.80 m
Same 5x5 points measuring grid
Thanks,
Jose
Workplane Results
Calculation Surface Results
Calculation Surface 1.JPG (143.45 KiB) Viewed 313 times
Re: Min value in measure grid different from results overview
Post by T.Magenheimer » Mon Mar 29, 2021 3:37 pm
Dear Jose,
It is simply not always the minimum value and/or the maximum value that is displayed in the value grid for reasons of space.
Users browsing this forum: No registered users and 6 guests
