Problem with a roof
AlexG
Problem with a roof
Post by AlexG » Mon Apr 19, 2021 10:50 pm
Somehow a got an extra roof that I can't delete or move.
Can you tell me why?
What can I do?
Here you can find a view of the building.
https://earth.google.com/web/@38.251257 ... 92508t,-0r
It has many different roofs.
Thanks in advance
Alex G.
Re: Problem with a roof
Post by Csuleiman » Tue Apr 20, 2021 8:30 am
Hello Alex G.,
Please provide us with the evo project file so that we could check the problem directly in evo 9.2. It would be of help if you could send us the link to this topic so that we could better assign this issue. Our email address is 'Support@dial.de'.
Post by Csuleiman » Tue Apr 20, 2021 1:06 pm
Hello Alex G.,
Thank you very much for sending us your project file. It was a geometry problem, which we could fix directly in your project. Afterwards, we were able to delete the problematic roof. We will send you the edited project file via email. Please check if the problem you described still exists or if you can continue working with this project status.
You should create a separate storey for the roof and construct a separate room for each roof section into the attic. In this way, many open holes in the roof should be closed, because when you construct a room, new walls can always be created.
If gaps continue to be visible afterwards, you must close them with the help of narrow extrusion volumes. Although this is not an optimal solution, it is the only possible solution for complex roof constructions.
You can only remove overlapping parts with the help of cut-outs.
Have you already taken a look at our helpful video tutorials? Here you can watch a lot of videos that can help you with your planning: http://www.youtube.com/user/TheDIALux/videos
These videos describe the approach to constructing complicated roofs:
https://www.youtube.com/watch?v=jOjEAYkGTQw
https://www.youtube.com/watch?v=5pIBNNfHzpU
