led strip
AlexG
led strip
Post by AlexG » Thu May 06, 2021 11:05 am
Hello
1) In the Manufacturer, I can see ERCO Lighting but I can't in the product search. Why?
2) I got a room with a led strip and a box under an "insert seiling". But the result is not what I expect.
Do you know where can the problem be? The light seems to go over the box.
Thanks a lot
image 1.jpg (24.95 KiB) Viewed 361 times
image 2.jpg (9.13 KiB) Viewed 361 times
Re: led strip
Post by Csuleiman » Thu May 06, 2021 11:43 am
Hello AlexG,
The first point is not entirely clear for us. Could you please describe your problem with Erco in more detail. Preferably by means of some explanatory screenshots.
There are two alternatives for planning a light cove. Either you insert room elements or use a suspended ceiling, which you would of course have to process by means of a cut-out. This way, no light should escape downwards, which is the case when using cuboids.
AlexG
Re: led strip
Post by AlexG » Fri May 07, 2021 11:45 am
I can see ERCO
jpg 1.jpg (204.55 KiB) Viewed 344 times
I can't see ERCO
jpg 2.jpg (205.98 KiB) Viewed 344 times
I can't find ERCO
jpg 3.jpg (156.83 KiB) Viewed 344 times
Thanks with the second point. With a room element works.
Re: led strip
Post by Csuleiman » Fri May 07, 2021 12:21 pm
Hello AlexG,
Erco is our DIALux partner, but has not yet entered into a Lumsearch partnership. Therefore, you will not find this manufacturer in Lumsearch. However, you can download the Erco plugin or use the online catalogue directly to get the luminaires you are looking for.
Users browsing this forum: No registered users and 7 guests
