Problem with WORK AREAS
TomVanRoey
Post by TomVanRoey » Fri May 14, 2021 2:27 pm
Hi guys,
I'm having problems with the false colours visualisation in the documantation.
The background area is at 0m height and the colours are dislayed correctly
The surrounding area is at 0.8m and also displayed correctly.
The visual task area is also at 0.8m but the colour displayed is that of the background area, thus at 0m and way darker than the surrounding area while it should be the brightest colour.
The calculation value of the visual task area is correct, thus higher than the surrounding area and way higher than the background area, it is just the colour that is wrong.
I'm having a hard time constantly explaining that to clients.
Below is an example.
Re: Problem with WORK AREAS
Post by T.Magenheimer » Mon May 17, 2021 2:33 pm
Hi Tom,
Please send us the problematic project file for an analysis to the mail address 'Support@dial.de'.
In addition, please explain to us in more detail with further screenshots which area in the output is faulty and for what reason.
Post by Csuleiman » Fri May 21, 2021 1:58 pm
Hi Tom,
Unfortunately, you detected a bug in our current evo version. Our development team will analyse the problem furthermore and find a solution for one of the next evo versions as soon as possible.
