Rotate the fittings beam distrubition individually
andersoncheng
Post by andersoncheng » Wed May 12, 2021 3:35 am
Hi Lighting Experts,
How do I rotate the beam individually if I array the fittings arrangement through Dialux line function.
Please help me out. :)
Coz the client wants to see the beam highlight on different located featured products.
I don't wanna locate all fittings again individually, it is quite time-consuming.
BR,
AndersonImage[/img]Image
individual rotate.JPG (148.83 KiB) Viewed 242 times
Re: Rotate the fittings beam distrubition individually
Post by Csuleiman » Wed May 12, 2021 7:00 am
Hello andersoncheng,
If you select the line arrangement once, all luminaires of this arrangement are selected. However, as soon as you select a luminaire from this line array a second time, only this individual luminaire is marked as selected. This means that if you click twice with the mouse, you can adjust the alignment of the corresponding luminaire.
