I can't see the mast geometry in the simulate road lighting
Abrahamcañas
Post by Abrahamcañas » Wed Dec 31, 2014 9:26 am
Hello dears,
I'm From Chile and my problem is that when I simulate a road lighting in Dialux 4.11 in the rendering 3D only I can see the housing of the luminaire and I can't see the mast or post geometry. That happens with some luminaries.
What can I do to view the mast geometry in the simulation 3D??
I hope you can help me.
Thanks!!
M.Holthaus
Re: I can't see the mast geometry in the simulate road light
Post by M.Holthaus » Tue Jan 06, 2015 9:23 am
Dear Abrahamcañas,
To get the mast of the luminaire in the street light calculation, the luminaire has to have the correct mounting type. (Pole integrated or pole top mounted)
If this is not the case, DIALux does not construct such a mast.
If you would like to look for such luminaires you can use https://lumsearch.com/ to look for special luminaires which satisfy your requirements.
Maurice Holthaus
